Go Back   AudiWorld Forums » Technical Discussion » Performance and Tuning
Old 06-16-2003, 10:19 AM   #1
xr4tic
Account #: 12130
Default VR6 TB installed, along with new cylinder head.....
My stock TB failed, and put my car in limp mode, and my old head was blowing out a ton of oil smoke on startup.
I found that my old head was warped 0.010" and crossed my fingers hoping that it was the reason behind the mysterious coolant loss and brown sludge in the coolant tank
I also port matched the intake and exhaust ports to the gasket. I opened the intake ports on the head to the size of the gasket, and the intake ports on the intake manifold to about 1/16" less than the gasket.
I found that I had to remove material from the top of the port on the head, the bottom was good, and remove material from the bottom of the port on the manifold, the top was right on.
This means that in the stock configuration, the head intake port jutted into the air stream on the top (which is where the injectors are firing)
For the exhaust, I opened the manifold to the size of the gasket, and the head to 1/16" less than the gasket. I didn't have to remove much material here either.
New head is on, no more coolant loss, and no more oil smoke on startup - just fuel smoke on startup
Anyway, for the VR6 TB, I suggested welding up the old holes, and drilling new ones, then my dad came up with the idea to thread some aluminum rod, insert it into the TB holes, then drill and tap new holes.
So that's exactly what we did. Bought some aluminum rod, had to grind it down in size a little bit, then thread it, insert it into the manifold, and grind them flush. No welding required
Then just drilled and tapped new holes:
Yeah, they're a little crooked, oh well.
The scribed line is how much material needs to be removed:
Material removed:
Comparison pic:
The VR6 throttle body mates up perfectly with the stock manifold, almost like it was made for it
The VR6 has a slightly different throttle cable attachment point, which puts a lot of slack in the cable. I had to adjust the cable out as far as I could go, and put spacers on the cable bracket to space it out.
I also lost my cruise control capability, which kind of sucks, because now I have to actually watch how fast I'm going, this car is just too easy to go too fast
I just realized I don't have any installed pics, so I'll snap some tonight.
xr4tic is offline   Reply With Quote
Old 06-16-2003, 10:22 AM   #2
xr4tic
Account #: 12130
Default and the VR6 vs. stock TB pics...
in case anyone missed them last time.
You can sort of see the throttle cable mount is a little different, and there is no cruise control spot.
Front:
Back:
Side:
Old 06-16-2003, 02:21 PM   #3
cuatrokoop
Account #: 28712
cuatrokoop's Avatar
Default Re: VR6 TB installed, along with new cylinder head.....
Looks good! Can't wait to get to that point with the 10vt (needing a new, larger, TB)...
http://cuatrokoop.audi-quattro.org/intro.htm
"SECRETARY OF ENERGY AND AE ASSWHIPPINGS:
We call him when we need a big plane that kills people."
cuatrokoop is offline   Reply With Quote
Old 06-16-2003, 04:40 PM   #4
xr4tic
Account #: 12130
Default and the installed pics....
Notice the high-tech spacers on the cable bracket.
Old 06-16-2003, 04:52 PM   #5
Durrrrty Dufour
Account #: 55449
Default where did you get the throttle body??...
and how much do they usually run? any info would be greatly appreciated
thanks,
andrew
Disclaimer: chances are something in my post will be spelled wrong, since I am teh suck at teh spelling (and grammar/punctuation). Please refrain from pointing these mistakes out to me as I will not learn from my mistakes.
When I want your opinion, I'll give it to you
AIM: dufsB5turbo
High end road bike parts FS
Check out:
Induktion Motorsports
great shop
Durrrrty Dufour is offline   Reply With Quote
Old 06-17-2003, 12:53 AM   #6
SMOKINA4TURBO
Account #: 11056
Default Re: I can sell ya an extra one for $100, email me
SMOKINA4TURBO is offline   Reply With Quote
Old 06-17-2003, 05:49 AM   #7
squidix9
No Bozos!
Account #: 33772
squidix9's Avatar
Send a message via AIM to squidix9 Send a message via MSN to squidix9 Send a message via Yahoo to squidix9
Default Be careful
matching the ports to the gasket.
I just went through that with mine, and found every gasket I checked was different.
The biggest difference was in the size and location of the smaller water ports.
Especially if you've milled the head, make sure the ports haven't migrated in location. If a port comes in at an angle, as you remove material if will move.
Since you've already port matched this one, make sure you use the same gasket(mfg) again if you ever need to do any head work, and re-check the match.
squidix9 is offline   Reply With Quote
Old 06-17-2003, 06:36 AM   #8
VAP
Account #: 711
Default why don't you send me the bore diameter, "exact" length and desired O.D. for those...
nut-spacers and let me turn you up something a little more tastefully done on the lathe. I have a ton of 7075 aluminum rod stock sitting around thats just the right size. "On the house" of course. Just send me a postage-paid little padded return envelope and I'll get em right out.
All I need know is the bolt diameter going thru them, how long you want em and what O.D. In exchange I'll let you draw me a schematic of how I need to wire that Harlan RPM switch into the solenoid we talked about at "that other" forum.
VAP is offline   Reply With Quote
Old 06-17-2003, 09:48 AM   #9
xr4tic
Account #: 12130
Default I had two gaskets, both were the same...
luckily, we don't have any water ports between the head and manifolds.
Old 06-17-2003, 04:45 PM   #10
skabaru
Account #: 4670
Default congrats on getting her running well again!
now what is the narrowest point from the turbo to the throttle body? I would love to do the same mod, but since the stock turbo and the cross pipe are both too narrow to make a big difference...
so when you coming down here?
aim: skabaru
Check out my Fotki Album For Nearly All Mods...
winter mode in effect
My Mechanic Rules | The ACCCC Rules | mk2dev.com
Click to subscribe to Chicagoland Audi GTG List
"More Chicago Audi Crap Than You Could Ever Want"
<a href="http://www.nerdtests.com/ft_nt2.php">
skabaru is offline   Reply With Quote
HTML code is Off
