Go Back   AudiWorld Forums » Technical Discussion » Performance and Tuning
Old 03-31-2003, 05:45 PM   #1
xr4tic
Account #: 12130
Default FMIC installed, finally!
Spearco IC, Core is 3" thick, 20" long, 6" high
2.5" inlet and outlets.
Bought it off of ebay a while ago, very similar to this Ebay IC
I bought two 2.5" mandrel bent U-bends and one 2" U-bend from JCWhitney, approx $60.
2" pipe comes off the compressor, goes down, and angles out towards the bumper to a 2" to 2.5" adapter ($20), then 2.5" bend to the IC to 2.5" coupler ($5), then IC and another coupler ($5) to 90 bend in, 90 bend up to a 2.5" hump hose ($20) to a ~45 bend towards the TB, to two more couplers ($10) into the TB.
Topped off with Hose Techniques T-bolt hose clamps ($6.50 each x 13)
So total cost is about $600, including shipping charges.
I welded 3 tabs on the IC, 2 top, 1 bottom, then made some brackets out of 1" wide aluminum strips
Click on any pic for a larger view.
You can see how tight it is here with the MAF shoved in there also. I had to bend the AC lines down to make more room.
Showing the brackets and initial piping layout
Couple of front shots. Looks like my bumper is tweaked a little, I'll have to find out why.....
This is where my MAF will be going, where the short section of pipe is:
xr4tic is offline   Reply With Quote
Old 03-31-2003, 06:01 PM   #2
birdsong
Account #: 51152
Default Re: FMIC installed, finally!
You better stop posting stuff like this =P. Because all your tweaks want me to spend money I don't have. For example, I really feel like buying a 2.0L ABA engine off of ebay and building it up piece by piece in my garage after looking at your 2.0L conversion. So, in short, keep doing cool stuff even if it makes me want to spend more money.
birdsong is offline   Reply With Quote
Old 03-31-2003, 07:47 PM   #3
markbradford
Account #: 129
Default Are you keeping the SMIC too John?
markbradford is offline   Reply With Quote
Old 03-31-2003, 08:10 PM   #4
xr4tic
Account #: 12130
Default Nope, it's gone...
it was just in the one pic because I hadn't got around to pulling it out yet, I was just working on the mounts.
Old 03-31-2003, 08:12 PM   #5
nick n
Account #: 126
Default hey john..
I really like the sig!
nick n is offline   Reply With Quote
Old 03-31-2003, 09:17 PM   #6
SMOKINA4TURBO
Account #: 11056
Looks good! Get ready for some more timing:-)
Im interested to see how the MAF does there.
I also have been up to no good.
SMOKINA4TURBO is offline   Reply With Quote
Old 03-31-2003, 10:51 PM   #7
Dead
Account #: 8297
Default Am I seeing things?
Or is your car really clean?;-)
Dead is offline   Reply With Quote
Old 04-01-2003, 08:54 AM   #8
CharlieGSanD
Account #: 8383
Default your putting the MAF post turbo?
dont you think the increased temps will shorten its life?
Wrecked on 3/18/04 by a BMW 318ti who was in too much of a hurry to use the center lane, or check for oncoming traffic before turning left.
Replaced with an 03 Lancer Evolution
-------Engine & Drivetrain------
"Built" 1.8t W/ Forged Crank, Rods & Pistons, 8.5-1 C/R, Turbo upgrade, Spec S-III Clutch, Blitz SBC-id Boost Controller, Aquamist Water Injection, Ignition Solutions Coilpacks (removed), Turbo-5 FMIC, 3" High-Flow RennKat, 2.75" Prototype exhaust, Electric fan kit, Beru spark plugs, Red Silicone Vacum hoses W/ "Oetiker" clamps, Jaz PCV catch can, Forge Bypass-Valve (shimmed), Optima "Red-Top" battery, A.W.E Drive Train Stabilizer, APR snub mount, C&M Oil filter, Royal Purple 75w-90/tranny-diff, S4 wheel well liners left/right & a ghetto marmot scoop
------Suspension & Wheels-------
OZ Evo Chrono 17x8" W/ Falken Azenis Sports 225/45-17, 312mm Crossdrilled/Slotted Rotors, TT caliper carriers, Mintex "Red-Box pads", ECS Stainless-Steel Brake lines (6), Pentosin brake fluid, CPP Upper Control Links, Eibach springs up front & Neuspeed Race in the Rear, Neuspeed-Bilstein shocks & 19mm rear sway bar, LLtek front strut tower brace
------Accessories------
GReddy turbo timer & 60mm Boost/EGT/Air-Fuel guages, Defi H.U.D Speedo & Tach, Valentine-1, UUC short shifter, MOMO shift knob, MOMO E-brake handle with boot, Oettinger Pedals, Interior trim painted Brilliant Black, S4 Euro Projectors w/LED sidemarkers, slightly modified S4 Bumper, LED brake lights, Hella Smoked sidemarkers, one touch up rear window mod, Kamei Grille, Audisport all-weather mats, Audi Valve stam caps (STOLEN), Smart-tire Gen 2 system, Hella "Super-Tone" horns, Eclipse 7002 Audio/Video System, 8-disc changer (trunk), DVD player (passenger footwell), PPI 200x2 bridged to an Infinity Kappa Perfect 12" sub
Braintrust Id #2000
CharlieGSanD is offline   Reply With Quote
Old 04-01-2003, 08:56 AM   #9
CharlieGSanD
Account #: 8383
Default wow, cool FPR
lol
Braintrust Id #2000
Old 04-01-2003, 09:01 AM   #10
xr4tic
Account #: 12130
Default Yep....
I can't imagine it's much worse than having the MAF next to a hot turbo.
It's not the stock MAF, it's made to handle blow-thru applications.
If it can handle non-intercooled supercharged mustangs, I'm sure it will be fine in my car
HTML code is Off
