Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk1) Discussion
Old 08-27-2005, 08:15 PM   #1
Airbag79
Account #: 91434
Default My spare key is not working>>
assume it's a rolling code issue, can I correct this via VAG-COM, If so anyone know the procedure? I have the bentley, is it in there? Thanks in advance.
REVO 91, Schwing Stage 3, Borla catback exhaust, AWE Boost gauge, Hyperboost HX Compact DV, 3M 20% tint.
Airbag79 is offline   Reply With Quote
Old 08-27-2005, 08:55 PM   #2
shifTT
Account #: 75098
Default the remote door lock/unlock or the car can't be started with the key?
shifTT is offline   Reply With Quote
Old 08-27-2005, 09:14 PM   #3
andrew.tt
Account #: 50780
Default do a search for >>
reprogramming the key fob.
Check out the APR stage 3 dyno results
andrew.tt is offline   Reply With Quote
Old 08-28-2005, 04:35 AM   #4
MarTT
Account #: 20368
MarTT's Avatar
Default Here's a link to an article . . .
but I also have this procedure on file that is similar:
Step 1) With one key, turn the ignition switch on. Don't start the car, just turn the ignition on so the instrument cluster lights up.
Step 2) Open the window. Not neccesary, just a safety precaution to keep from locking the keys in the car :-)
Step 3) Close the driver door and lock it with the other key.
Step 4) Hold down both the Lock and Unlock buttons on the remote for a few seconds (may be upt to five seconds). After a couple of seconds you should get the honk and flashing lights.
Step 5) Open the door with the key, and turn off the ignition.
Your remote should now work.
MarTT is offline   Reply With Quote
Old 09-27-2005, 04:03 AM   #5
lkeneston
Account #: 85545
Default Re: the remote door lock/unlock or the car can't be started with the key?
I have the same issue, My Wife's key fob works to lock and unlock the car, but it will not start the car, it turns over looks like it will start then dies..
lkeneston is offline   Reply With Quote
