2001 225 TTCQ MODS: /H&R SP.Springs/Bilstein Sp/Bailey DV/RH Cuprad Wheels18x8.5&18x10/25mm H&Rspacers(adapters)F>R/Ziex-Z 912 Falken's on:235/40/18-265/35/18/WINTER WEAR:225.45.17Nokian WR's on Stock 17 5 Spokes /Schwing's TTDA/GIAC-X Chip/Escort8500/Neuspeed Short Shift kit/Rear Red painted Calipers,Audi Rings/Bird Automotive Armrest/19mmRear Neuspeed Swaybar/Rear Harness Bar/1/2 KMAC for rear/Forge Hi-Flow Exhaust/Raffi Knob(Race -2)/Samco Intake Hose/IK-22 Densos/Descreened,Devaned/Mantis,with 2VDO Gauges Oil Temp and Volt/Dogbones/Defi D Boost Gauge.Pillar Pod/3.2 Rear Valence(modified)/4Bar FPR,MOFO/Telson(FG)3.2 Spoiler/Wilwood 13"BBK,Red 4 Piston Forged Calipers/Dr. SchwingsBoost Machine/Hella Horns/Quattro Sport Gl.Box Emblem/ECS tuning Poly Control Arm Bushings/EVO Phenolic Intake Manifold Gasket/Optima Redtop/Revo 93 on an xtra ECU/passenger side EURO Mirror/Mark 1 Arms/Rear cross drilled Zimmermans/Street Concepts 3 Piece Front Splitter w CF center/Riso Carbon Fiber Door handles/42DD Dwn Pipe/MT-90 TrannyOil/22mm Nuespeed front swaybar/Alcantara E Brake handle/Tyrolsport UG SMIC's(2)/http://us.fotolia.com/p/51995?order=nb_downloads&offset=96
<------------------------------------------------------> "... hope everyone realizes i have never made a serious post in my life and that i never check my spelling or grammer." |
one is a standard 9 pin serial, the other is a usb. you have to get a slightly different version of VAG to use the usb version. also, if you have an old laptop, some of them didn't have the uart chip that was fast enough, but that's only on old stuff.
USB Vag-Coms should work with most win98 and up laptops w/ USB ports. The serial ones *should* work with any laptop with a serial port. I think some newer laptops don't come with serial ports on the back though. On newer laptops with serial ports, sometimes the port has to be configured correctly to work with Vag-Com. Hope this helps.
_______________________________________ Some Pictures... ![]() Pictures hosted by Hostdub.com Timing belt replacement post Downpipe replacement post |
I haven't heard yet regarding the newer style USB connection. Ross Tech is one of few companies that I deal with who stubbornly refuse to support the Mac. You might check to see if they've updated their FAQ list on this.
Cheers, Rich
I just got the shadetree prodiag, so far so good. i run the rosstech version on my wifes dell laptop when i need it, but having it on my palm is sure handy
#10 |
using the serial cable and an adapter, running virtual PC. It was recent too (last 2-3 months or so). The USB is supposed to work too.
