Old 05-27-2003, 10:10 AM   #1
Žob
Account #: 475
Default 2.8 Camshaft tensioner seal replacement process
This is how to replace the camshaft adjuster seal on the head.
I won't bother with pics/details on how to get up to this step other than, of course you need to set the engine at TDC, make sure cams are ligned up, remove the valve cover etc. You don't need to remove the timing belt for this process which is very nice.
Once the cams are lined up and the engine is at TDC, to make it easier on yourself, grab some nail polish/paint marker and mark the marks on the chains on the cam and the one at the pulley for TDC. See the marks I made for the cam chain below. Notice the notch and the arrow line up with each other. Also, it is exactly 16 chain links to and from each notch. So keep that in mind for reassembly.
Next, install the special Audi tool for compressing the cam shaft tensioner. This tool is a MUST to do this job. Tighten it down, but be careful to not to go crazy. You should see slack in the chain once tightened like this.
Next, remove the bearing caps on the intake side. Make sure not to not mix them up or install them backwards. They are numbered which helps. You also need to undo the cam shaft position sensor. Once all the bearing caps are loose on the intake side, I also undid one exhaust cam bearing cap close the cam chain.
The cam probably won't pop right out, so grab a pair of channel locks and and grab the cam on the rough casting (where you won't hurt it) and wiggle the cam back and forth to loosen it. You'll need to remove the 13 mm nut that holds the power steering hose in place. It is located behind the head . Just follow the hose down and you'll see it. Once the cam is loose, you can then rotate the whole cam with chain attached to the side just enough to get the gasket out from underneath it. Reassembly is reverse of removal
Once reassembled, you want to rotate the engine by hand to make sure everything is OK. The 2.8 uses 24 MM 12 point socket on the main crank bolt. When you rotate, you'll see the cam chain marks won't line up again, that is normal. Just make sure there is 16 links apart from notch to notch and you are OK.
I used to own a B5 A4, now I have this and am never looking back.
Žob is offline   Reply With Quote
Old 05-27-2003, 10:15 AM   #2
WYSIWYG
Account #: 12079
Default Where's the beef!?!
ok ok i'll let myself out
Edward Morfe
WYSIWYG is offline   Reply With Quote
Old 05-27-2003, 10:16 AM   #3
RKA
Account #: 2062
Default Nice write up Rob! Thanks!
I take it this will end up in your tech section (just so I know where to look for it, if I ever need it)?
2005.5 A4 Avant 2.0T Quattro 6MT
APR 91/93/100 | APR Exhaust | 19" BBS RS-GT's | Carbonio | Hotchkis | Partridge-in-a-pear-tree
Others:
2006 TL on the block
2001 S4 sold
2000 A4 sold
*** September 11th, 2001 - Never Forget ***
RKA is offline   Reply With Quote
Old 05-27-2003, 10:18 AM   #4
Žob
Account #: 475
Default Yes it will...
Old 05-27-2003, 10:22 AM   #5
ModifiedA4
Banned
Account #: 143
Default nice!
ModifiedA4 is offline   Reply With Quote
Old 05-27-2003, 10:42 AM   #6
moribundman
Account #: 50038
Default Are you gonna do the front camshaft seals on occasion?
They should be similar to the ones on my 12v...
By the way, there's no camshaft tensioner in my 12v. This engine hasn't been overdeveloped. ;-)
Mhmm, donuts...
moribundman is offline   Reply With Quote
Old 05-27-2003, 11:03 AM   #7
Žob
Account #: 475
Default the camshaft seals don't typically go bad...they are still good on my car
Old 05-27-2003, 11:25 AM   #8
Kris Hansen
Chief of Goat control
Account #: 20
Kris Hansen's Avatar
Send a message via MSN to Kris Hansen
Default Nice Rob.. To change the actual tensioner you'd need to remove the belt though, right?
Looks easy enough.. If only I had the time. My driver's side tensioner is bad, the passenger side one leaks.
Kris Hansen is offline   Reply With Quote
Old 05-27-2003, 11:26 AM   #9
moribundman
Account #: 50038
Default Cross your fingers, knock on wood, break a leg!
Mhmm, donuts...
Old 05-27-2003, 01:49 PM   #10
Žob
Account #: 475
Default To change the tensioner...
you would need to remove both cams, so yes, it would be requiring you to remove the belt.
How do you know your tensioner itself is bad?
18t, 28, a4, audi, audiworld, b5, cam, camshaft, chain, process, removal, replacement, seal, tensioner
