Old 07-31-2008, 05:22 PM   #1
asm72ecko
Account #: 128087
Default What are everyones feelings on water/methanol injection kits?
and why? Im thinking about getting a kit but am not sure how our cars will do with it. Anyone with experience?
2001 Audi A6 2.7t: Special Edition, Sport Package, Black on Black, APR 93 octane program, Navigation, Bose Audio, APR Bipipe, 710N's, IPP Intercoolers, Custom 2.5" Exhaust, Stage 2 Darintake, ABD Racing Big Bore intake, H-sport sway bar kit, Slotted/Drilled Rotors
asm72ecko is offline   Reply With Quote
Old 07-31-2008, 05:22 PM   #2
blAck6 (desairs)
Account #: 134622
Default check the b5 s4 forums. you might get help there
blAck6 (desairs) is offline   Reply With Quote
Old 07-31-2008, 05:43 PM   #3
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Default Why do you need a kit? What is the goal?
4Driver4
"Never give up the throttle until the bitter end." -RC
1990 Coupe Q
1999 A6 Sedan Q 2.8
2000 A4 Avant Q 2.8
1995 Mazda Miata: the anti-Audi
1999 Mazda Miata: Track beotch
1999 Chevy Suburban: the anti-earth :-(
1990 Nissan Pickup: Snow plow/garbage hauler
1981 VW Scirocco: the car I shouldn't own
4Driver4 is offline   Reply With Quote
Old 07-31-2008, 07:12 PM   #4
KillA6
Account #: 85994
Default Do a search in the B5 forum lots of info. I am going to put one in by next summer after I am
full stage 3. I'll be full stage 3 by summers end this year but my wallet will be strained.
I hear lots of good things about it. They just had a group buy from VAST for their kit.
2000 A6 2.7 stage 3-
Stasis 6-speed trans
GIAC Chip
KO4's
RS6 Intercoolers w/ RS4 encaps
5 bar FPR
Hitachi MAF
JHM shift linkage upgrade <-- Great upgrade!!
034 track density motor/trans mounts
LWFW CM stage 4 clutch <--- crap crap crap!!!!! I switched to resurfaced FW and VAST clutch. So far so good!
Piggies
APR Snub mount
B&M Short shifter
H&R sport springs/sway bars
Bilstein shocks
Magnaflow Mufflers
stage 3 fueling/software by ?????
Things I need :
rear view mirrow (auto dim)
myspace.com/ninjaed
KillA6 is offline   Reply With Quote
Old 07-31-2008, 07:38 PM   #5
rageman
Account #: 92262
Default Do it! I have a Snow Performance kit on my car - def runs better IATs and timing.
I don't have a timing log graphed, but I think that I was ~10º without the meth and 18º with. Here is an IAT log:
Poor resolution as VAG-COM is all I have to work with - and RPM scale is not accurate across all runs (temp is though).
rageman is offline   Reply With Quote
Old 07-31-2008, 08:27 PM   #6
audikillsbmw
Account #: 121340
Default Usually meth kits are used to supplement a system that is less than adequate (i.e. if you
are unable to install large enough intercoolers, drop compression to a low enough level, etc.) They can certainly be used in conjunction with a functioning system though.
Johnny B.
- OFFICIAL 2007 C5 A6 POST WHORE -
- OFFICIAL 2008 C5 A6 POST WHORE -
R.I.P. Thor- 10/97-8/08.. I miss you buddy :(
Racing Green PE 2000 A6 4.2: All options except warm weather & Sport package...
MODS: Bilstein shocks, H&R Sport springs, 18x8.5" wheels (et30) with 235/40's, blacked-out RS6 upper grille, debadged, 15mm (F) and 20mm (R) spacers (SOLD,) Darintake mod (w/screen,) 00032 trans recode, high flow race cats (courtesy of 034 Motorsport,) plain black 3-spoke steering wheel, 605 "mod", painted rear valance, drilled rotors F&R, Metal Master front pads, VAST performance fan, clear corners, and various other things.
FUTURE PROJECTS: NONE. She will be gone soon.
Previous Rides:
1996 A4 2.8Q
1992 Acura Legend LS sedan
1986 Ford F-250 2WD
audikillsbmw is offline   Reply With Quote
Old 07-31-2008, 09:25 PM   #7
audifreakjim
Account #: 3645
Default Yellow car runs it, makes a difference on pump gas.
Jim Green
'89 90tq 034EFI GT35R
http://www.mswanson.com/~jgreen/car_home.html
'01 A6, the "ocho"
***The wheels are for sale***
audifreakjim is offline   Reply With Quote
Old 08-01-2008, 08:20 AM   #8
Li3ny
Account #: 81774
Default Make sure you have someone who can properly tune it.
I gave it a shot for a while, it definatly got my AITs down. But I couldn't... or I should say I'm not confident enough to really tweak it myself. I had issues w/ my car running lean. It also started having cold start symptoms again, except without the starting part. I just couldn't shake the idle surges. Spoke w/ ASP who said they could tune it, I just never got around to it. Ultimatly I just ended up ordering bigger intercoolers(ERs), a lot less hassle and safe for the motor.
Li3ny is offline   Reply With Quote
