Old 06-11-2008, 05:07 PM   #1
tslag
Account #: 89885
Default Econ light stays on fault code 00819
Hello,
I have searched this forum but didn't find an answer to my question.
I have a 2002 A6 4.2. The econ light on the climate control will come on and stay on about 5 minutes into driving, meaning I have no A/C. I had the car VAG'd today and here is the fault:
00819 - High Pressure Sensor (G65)
29-00 - Short to Ground
I found the following article on Ross-Tech:
http://wiki.ross-tech.com/index.php/00819
The recommended solutions are:
00819 - High Pressure Sensor (G65): Signal too Low
Possible Symptoms
* Climate Control stuck in ECON Mode
Possible Causes
* Insufficient Refrigerant Pressure
* Wiring/Connectors from/to High Pressure Sensor (G65) faulty
* High Pressure Sensor (G65) faulty
Possible Solutions
* Check Refrigerant Pressure
o Check Measuring Value Blocks (MVB)
* Check Wiring/Connectors from/to High Pressure Sensor (G65)
* Check High Pressure Sensor (G65)
My question is:
Should I have the system checked for low refrigerant before replacing the sensor? The 29-00 Short to ground from the fault code makes me think the actual sensor may be bad. Has anyone had this same code before? Any suggestions?
Thanks in advance.
tslag is offline   Reply With Quote
Old 06-11-2008, 05:14 PM   #2
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Default I'd say yes. Have the system checked.
4Driver4
"Never give up the throttle until the bitter end." -RC
1990 Coupe Q
1999 A6 Sedan Q 2.8
2000 A4 Avant Q 2.8
1995 Mazda Miata: the anti-Audi
1999 Mazda Miata: Track beotch
1999 Chevy Suburban: the anti-earth :-(
1990 Nissan Pickup: Snow plow/garbage hauler
1981 VW Scirocco: the car I shouldn't own
4Driver4 is offline   Reply With Quote
00819, 2002, 2004, a4, ac, audi, code, econ, g65, high, light, low, pressure, sensor, signal, stays
