Old 03-30-2006, 08:46 AM   #1
Boston Driver
Boston Driver's Avatar
Default Just because some here might be swapping out interior trim...
here are the removal steps that I followed, basically a repost of carbonLORD's 3 seperate posts on this very topic. If I have a chance, I will update with some pics later.
Door trim removal: use a plastic putty knife (or a metal one with tape to protect the trim) and work from the lower-rear corner. It is held in by metal pegs that are on the metal backing of the trimpiece. If it is stubborn, use some dental floss, and work it into the back of the trim to the point where it will give you some leverage.
Dash trim removal: Again, use the plastic putty knife and work from the lower outer edge. It is held in by four suprisingly long pegs that are on the back on the trim piece.
Shift surround: Use the plastic putty knife on the rearward edge and pull up. The rear is held in by two plastic blocks in a metal clip. Once the rear edge of the trim is loose, slide the trim toward the back of the car. There are two flat tabs that hold in the front under the ashtray.
Armrest tray: Work from the forward or side edge, and use the plastic putty knife again. The rearward edge is held in with a couple of small tabs. Once unsnapped, just lift the forward edge upward and slide forward to remove the tabs from the slots on the back edge.
Piece between brake lever and tray: Just use the plastic putty knife. Held in with a few small metal pegs.
Under armrest hinge: Remove the rear vent/cig lighter by using the plastic putty knife on the upper edge. Then remove the plastic vent piece (pull straight back). Once removed, you will see a nut in the right center in the middle of a rectangular bracket. Using a 13mm micro-adjust ratchet, remove the nut, and lift the armrest straight up (you might also need to unplug wires if you car is equipped with factory phone setup). Then using the plastic putty knife, remove the trim, which is held in with small metal pegs.
Brake lever: This one is a major PITA. Kind of hard to describe, but once the trim is seperated from the brake lever, you have to maneuver it around to get the lowest catch released from the hidden part of the brake lever. With the rear vent removed, it is easy to see what is holding this piece in.
Hazard switch trim: Suprisingly, this piece is one of the hardest to get out. Easiest way I have found is to remove the radio (which requires radio keys). Then using the plastic putty knife, work from the bottom. It is held in with 6, yes, 6 clips, many of which willl probably break in the removal process. Don't worry. Only two are really needed to hold the trim in place.
Ashtray cover: Lift up on the trim while using your thumbs to pry the upper edge back. Once the upper edge is released, rotate it down to release the loops from the hooks that are hidden under the ashtray. Be careful, these loops on the bottom edge break very easily.
I think that is it. Sorry, no pics yet, but hopefully this is descriptive enough.
2002 A6 4.2 Sport...with a few things added
Boston Driver is offline   Reply With Quote
Old 03-30-2006, 10:02 AM   #2
Deuce4.2
Default Instead of the putty knife you can use the handy dandy tools which TBG informed everyone of.
02 S6, OEM RS6 Wheels, RS6 Grills, RS6 Carbon Fiber, H-Sport, PSS9 Coilovers
SOLD - 00 A6 4.2
Deuce4.2 is offline   Reply With Quote
Old 03-30-2006, 10:09 AM   #3
Boston Driver
Default Yeah, but this for the everyday folks without special tools (other than the 13mm micro-adjust)
Old 03-30-2006, 10:34 AM   #4
Deuce4.2
Default I thought everybody bought the special tools :-)
SOLD - 00 A6 4.2
Old 03-30-2006, 11:50 AM   #5
TeddyBGame
Default cool. This will be handy for my upcoming interior UPGRADES.
TeddyBGame
As of November 2006:
Accessory Add-ons:
1) OEM winter floor mats
Upgrades:
9) ?
15) ?
Coming soon:
MODifications:
Old 03-30-2006, 02:08 PM   #6
Grapeking
Default what do you have up your sleeve now?
Grapeking is offline   Reply With Quote
Old 03-30-2006, 03:11 PM   #7
néné
Default I thought you had the Bentley?
If not, I do. Just call me with what parts you want removal info on.
www.htms.org :: www.RS6.com :: RS6 Trance Sessions
néné is offline   Reply With Quote
Old 03-30-2006, 03:17 PM   #8
TeddyBGame
Default I have the bentley...but can't seem to get it to work. I haven't used it in 2 years.
TeddyBGame
Accessory Add-ons:
Upgrades:
9) ?
15) ?
Coming soon:
MODifications:
Old 07-27-2007, 07:41 AM   #9
nocturnal28
Default Where did you buy the RS6/S6 Euro blue-weave carbon fiber trim
Hello,
I was wondering where you bought the trim and how much was it? Also, would it fit my 2002 A6 2.7T?
i looked everywhere online but could not find anything. I hate my wood trim, makes the car look so ugly inside.
Your help would be greatly appreciated.
nocturnal28 is offline   Reply With Quote
Old 11-23-2008, 03:26 AM   #10
hahayan
Default how long do it take ?
hahayan is offline   Reply With Quote
bentley, cryshler, interior, lcd, pacifica, removal, swapping, trunk
