Old 04-07-2005, 02:08 PM   #1
CGTBrad
Account #: 40192
Default Anybody do a xenon swap or parting out?
My cousin is in need of a passenger side headlight for is 2000 2.8 FWD Non Xenon. TIA =)
Brad B.
Nashville
1987.5 CGT 2.3 Special Build
2001 TT 225
CGTBrad is offline   Reply With Quote
Old 04-07-2005, 02:22 PM   #2
TeddyBGame
Account #: 32631
Default YGM.
TeddyBGame
As of November 2006:
Accessory Add-ons:
1) OEM winter floor mats
Upgrades:
9) ?
15) ?
Coming soon:
MODifications:
Old 04-07-2005, 03:04 PM   #3
CGTBrad
Account #: 40192
Default Thanks I'll pass on the info.
Brad B.
Nashville
2001 TT 225
Old 04-07-2005, 03:49 PM   #4
eh?6Q
Account #: 55916
Default Recently upgraded my 99 halogens to bi-xenons. (BWW)
The following is a step-by-step procedure with pictures of the conversion of a pre-facelift ('98-'01) halogen headlight to bi-xenon:
The shape of both headlight housings are different, but the internal guts can be transferred easily.
The chrome plastic shrouds that came with the xenon projectors have to follow along since the projector diameter is different and the mounting posts are longer and positioned differently.
The good news is that the shrouds fit inside the black housing in-place of the older ones without any modifications.
Split open both housings with a heatgun (see instructions for clear-corner in the tech section):
Have a micro-fibre cloth to clean-up all the chrome pieces.
I found this foam pad great to protect the chrome shround from scratches during dissassembly:
Remove reflector lower mounting-point (twist counter-clockwise).
Remove turn-signal reflector:
Release shround:
Repeat above for the three other headlights (1 halogen, two Bi-xenons).
Cut bi-xenon wires (to free-up the wiring harness):
Release turn-signal wiring:
Remove wiring harness:
In the original halogen headlight outer shell, make a hole for the ballast wiring harness:
Insert the bi-xenon wiring harness:
Optional steps begin here VVVVVVVVVVVVVVVVVV
Unscrew projector from shroud :
Remove shield (optional):
Re-attach Projector (if previously detached)
Optional steps end here ^^^^^^^^^^^^^^^^^^^^
Insert motor mount:
Begin the re-assembly process - in reverse order (Install the remaining bi-xenon parts into the halogen headlight - Except re-use the original turn-signal reflector.)
Reconnect (solder) the bi-xenon wires that were cut earlier.
Re-attach original halogen lens using heat-gun to soften the goo.
All done!
Note the slight difference in shape of the reflector shows a gap when viewed from the side. Not visible from straight-on (see above).
Test:
Installed:
I found it *_easier_* to remove the ballast before, and attach it afterwards. Have a magnet on a telescoping wand handy!
Substitute the 15 amp fuses with 20 amps.
Canadian cars require DRL's, and in 99 an A6 they were the low-beams. The xenon's do not like losing power upon cranking the engine since they are just warming up. They often shut-down. A simple cut and splice of one cable in the switch harness moves the DRL function to the fog lights. I have to check my notes - ask me later.
eh?6Q is offline   Reply With Quote
Old 04-07-2005, 05:58 PM   #5
CGTBrad
Account #: 40192
Default Uh thanks! But that's not the info I needed =)
Brad B.
Nashville
2001 TT 225
Old 04-07-2005, 07:53 PM   #6
CGTBrad
Account #: 40192
Default Thanks guys - we're all taken care of! =)
Brad B.
Nashville
2001 TT 225
Old 04-07-2005, 11:35 PM   #7
Sarge
Account #: 5500
Default Great post - Stoney? BTW, how did you re-attach the outer lenses? Epoxy?
How did you reattach the outer lenses after using the heat gun to remove them? just squirt some epoxy on there? Any special kind?
Thanks!
Current: <a href="http://forums.audiworld.com/allroad/msgs/251057.phtml">
'03 allroad 3.0T, 6M - Autospeed Lemon</a>
Past: '00 A6 4.2, '99.5 A6 avant, '91 200q 20v, '90 90q 20v, '86 5ktq
Sarge is offline   Reply With Quote
Old 04-08-2005, 05:42 AM   #8
TeddyBGame
Account #: 32631
Default Nice work...very impressed.
TeddyBGame
Accessory Add-ons:
Upgrades:
9) ?
15) ?
Coming soon:
MODifications:
Old 04-08-2005, 06:15 AM   #9
eh?6Q
Account #: 55916
Default Used the heatgun again. Soften up the goo, position lens into grooves, heat again (more)
...push all the way in, then re-attach the "C" clips.
Did this over 2 years ago for clear-corners, and to clean the magnifying-glass and inner side of the plastic lens. Never a leak, nor fog inside.
BTW: reinserting the entire housing back into the car, I found the C clip underneath closest to the flasher was interfering against the chrome trim. I removed it, since the lens at that end inserts into a deep groove that will not allow it to move.
Old 04-08-2005, 08:21 AM   #10
carbonLORD
AudiWorld Uber User
Account #: 33185
Default Excellent work, truly worthy of the Stoney Archives.
Where were you when I needed these on my 2.8?
Great work!
"Change is inevitable" | RS 6 Stuff | www.carbonLORD.com | 08 TT 2.0
carbonLORD is offline   Reply With Quote
c5, cd, changer, epoxy, plate, trunk
