Old 07-29-2004, 10:55 AM   #11
jwt2.7T
Account #: 22974
Default Antenna mounted to rear bumper support, above rear exhaust on driver's side..
...so I'm told by a local VW/Audi repair shop whose done good work for me before. I will check & let you know. He, too, shows the central locking control module under the driver's seat.
'00 A6 2.7T w/GIAC, straight angled rolled stainless steel tips (not currently shown in pics), driving lights mod, remote up/down windows mod, Equalizer mod, 5 spoked polished wheels w/235/45/17 Pirelli PZero Nero M&S (not currently shown in pics)
jwt2.7T is offline   Reply With Quote
Old 07-29-2004, 12:48 PM   #12
jwt2.7T
Account #: 22974
Default Keyless Entry range INCREASED to 100ft!!!! And took all of 45 minutes.
Thanks to everyone for their help & input!!! The clincher was a tip from my local VW/Audi tech, who said that the antenna was attached to the rear bumper support on the driver side. Sure enough, there was a coax-looking wire coming out of the body via a gromet & attached by like a tie-wrap to the metal bumper (seen by looking up thru the valence with a flashlight). I then went into the trunk & removed the driver's side panel door & felt around & look around @ the back of the cavity & right by the felt-trunk wall I found the same coax-looking cable. However, it was really just a tube, with an antenna wire running into it. I was able to just pull the ant. out of the tube & continue to pull it out of the wiring harness, next to the jack. I pulled it all the way out till it was @ the roof of the trunk. I then fed it thru the roof of the trunk & into the back of the rear seat & up onto the very back driver side window (the little one). I did this real quick @ lunch & thus could probably pull it even more out of the wiring harness & mount it in an even better place. But, as is, I now get 100ft keyless entry range on my 2000 A6 2.7t, w/o modifying the remote FOB or central locking control module!!!! Yes, now I can open/close my windows from the house. I still don't know where that thing is & really......it doesn't matter at this point. Enjoy the range!!!
Old 07-29-2004, 01:20 PM   #13
bitterman
Account #: 76738
Default pictures please
bitterman is offline   Reply With Quote
Old 07-29-2004, 01:27 PM   #14
jwt2.7T
Account #: 22974
Default Sure. I'll work on it. Maybe by tomorrow.
2001, 4b0962258j, a6, audi, central, control, entry, extending, keyless, locking, module, range, remote
