Old 05-24-2004, 06:26 PM   #1
Eric 2.7
Account #: 61325
Default Inside a suction jet pump. Sometimes I think it's a sickness which afflicts Audi engineers.
Here is a partial view of the inside of the problematic suction/jet pump. The straight connection on the left comes from the brake booster. The connection on the right goes to the manifold (vac source). The branch comes from the junction can for the breather system.
The two orange circles are rubber diaphram check valves. Vacuum pulls through two paths. One straight through and the other through the venturi side. The venturi side pulls vacuum from the branch trading velocity for vacuum level (? why ?). So here it is. WTF, mates.
Keep in mind that this animal only exists on certain models (Tips 2000, and I forget how far beyond).
Eric
2000 A6 2.7T
DIY Mule:
Full Timing Belt Replacement, Cam Seals & Cam Tensioner Gaskets, Engine Mounts (TWICE! Thanks Hamburg-Technic/ECS), O2 Sensors, 2ndary Coolant Pump, '03 OEM Sport Suspension, H-Sport Sway Bars, Control Arms, Tie Rod Ends, CV Joint Boots & All Kinds of Maintenance Stuff.
Retired:
1996 A4 2.8 2wd 12v
1987 4000CS Quattro
1980 4000 2door (not even an "S")
Eric 2.7 is offline   Reply With Quote
Old 05-24-2004, 06:29 PM   #2
2.7tDallas REFORMED
Account #: 71945
Default so when it gums up - the brake booster calls for mor vac to operate
then hwat happens?
2.7tDallas REFORMED is offline   Reply With Quote
Old 05-24-2004, 06:41 PM   #3
Eric 2.7
Account #: 61325
Default I'm thinking the branch/venturi side becomes clogged eliminating that pull on the breather
system while the larger bore side stays operational and keeps pulling from the brake booster as required.
The two halves are isolated completely from each other, and there are plenty of small clearances on the branch side to get gummed up.
I'd still like to figure out if I can just eliminate this puppy and connect the can directly to the manifold.
Eric
2000 A6 2.7T
DIY Mule:
Retired:
1996 A4 2.8 2wd 12v
1987 4000CS Quattro
Old 05-24-2004, 07:18 PM   #4
saabSean
Account #: 8108
Default We've got them on '99 2.8s
saabSean is offline   Reply With Quote
Old 05-24-2004, 09:12 PM   #5
NJ4.2GUY
Account #: 73864
Default I have a 2000 4.2
is that gonna go on mine too?
NJ4.2GUY is offline   Reply With Quote
Old 05-24-2004, 09:50 PM   #6
StoneMan
Account #: 47743
Default Pic got P0wned!
Jeez, and you'd THINK it would be Audi related!
StoneMan is offline   Reply With Quote
Old 05-25-2004, 04:15 AM   #7
Eric 2.7
Account #: 61325
Default Hey AWMODS, this is a part from an A6 - Audi Related.
Eric
2000 A6 2.7T
DIY Mule:
Retired:
1996 A4 2.8 2wd 12v
1987 4000CS Quattro
Old 05-25-2004, 05:46 AM   #8
JimR
Account #: 1018
Default FWIW - the parts and service guys at my local dealer call that a "suck pump".
JimR is offline   Reply With Quote
Old 05-25-2004, 06:27 AM   #9
Kris Hansen
Chief of Goat control
Account #: 20
Kris Hansen's Avatar
Send a message via MSN to Kris Hansen
Default Well, it *does* suck!! :-)
Kris Hansen is offline   Reply With Quote
Old 05-25-2004, 06:37 AM   #10
Eric 2.7
Account #: 61325
Default I don't see it on ETKA for a 4.2 so i think you are in the clear.
Eric
2000 A6 2.7T
DIY Mule:
Retired:
1996 A4 2.8 2wd 12v
1987 4000CS Quattro
18t, 27t, audi, bad, booster, brake, breather, clog, diy, jet, pump, suction, super
