Old 03-11-2004, 10:02 AM   #1
RostyVyg
Account #: 47928
Default V1 / Passport 8500 Hardwiring to the Autodimming/Compass Internal Mirror
This is a re-post with pictures on request of many viewers:
Thought you might be interested in another way of hardwiring the RD into an Audi with auto dimming/compass mirror. I tried this on 2003 A4, 2003 alloroad and 2004 allroad - works well.
Disclaimer - as usual, the poster of this thread is not responsible to any damage to your vehicle or radar detector. Please exercise common sense and use appropriate tools (including a voltmeter to make sure the polarity is correct).
Tools: Flat head medium size screwdriver, pliers, small scissors, a set of Radio Shack "Telephone Wire Tap Connectors" (part number 64-3081) and 5" of telephone wire with RJ11 jack on one end (this is for Valentine V1 or Escort Passport 7500 or 8500 - other models might require another connector on their end).
Time: 45 minutes if you have "two left hands", sooner if you are handy enough.
Misc. Notes: It is better to do this mod when it is daylight outside - you'll see things much easier.
1st step. Switch the ignition OFF! Unclip a plastic wiring cover protecting the wires coming from a headliner to the mirror (use the flat head screwdriver - pry on the passenger side first
Click on the image to get a bigger picture...
2nd step. Remove the wire connector from the retainer and if you want more freedom of movement, disconnect it.
3rd step. Splice longitudinally the rubber conduit (tube) BELOW the connector (on the way to the mirror) as low as you can to free up 6 wires: yellow, green, brown, gray, black and white. White wire is switched +12 volt. Power comes on when you switch the ignition only. Black wire is a ground wire.
4th step. Using the "Telephone Wire Tap Connectors" - perfect fit for these wire diameters - connect the telephone cord to the wires as low as you can (this way you would be able to tuck them into the wider part of the mirror base later). Make sure the wires coming to the mirror are pushed all the way into the connector groves (this will allow the connectors to slide freely along the wires before you finalize the connection) before squeezing the tap connectors with the pliers! You only need two telephone wires out of four available in the telephone cord. These two wires are supposed to come to two middle contacts on RJ11. Please use the diagram below. It assumes you are looking on the RJ11 connector from the bottom (clip is away from you).
5th step. Re-connect the mirror wire connector, switch on the ignition and check with voltmeter polarity of the power on the RJ11 connector. It should be exactly the same as polarity on the RJ11 at the end of the cigarette lighter power cord. If everything looks all right, connect the RD and check if it has power.
6th step. Switch the ignition back off. Tuck the "Telephone Wire Tap Connectors" into the wider part of the mirror base. Clip the mirror connector back.
7th step. Cut a small grove in the corner of the mirror wire cover depending which side you want the RD wire to exit to. I did it on the driver's side since the RD's in all my cars are attached via suction cups right above the mirror on the driver's side.
8th step - Re-clip the mirror wire cover.
9th step. Attach the detector to the windshield and plug RJ11 into it.
You are done!
For those who is wondering why I did not use any additional in-line fuse - the wires to the mirror draw power through the existing low current fuse already and there is no room for additional fuse in the mirror base.
RostyVyg is offline   Reply With Quote
Old 03-11-2004, 10:20 AM   #2
Mitch S6 Avant
Account #: 70048
Default Nice, I was just about to tackle this project! Thank you!
BBS LM's 19"x8.5" -SOLD
255/30/19 SportMaxx Tires still FOR SALE less than 4kmi asking $850 OBO
e-mail: mitchell.phillipi@comcast.net
'02 S6 w/H&R coils, BBS LM's and 255/30/19" Dunlop SP Sport Maxx
Mitch S6 Avant is offline   Reply With Quote
Old 03-11-2004, 10:38 AM   #3
drew2.7T
Account #: 58106
Default I have a bel under dash radar detector. It is placed on
The lip in front of the instrument display (right side / attached with velcro. I had an alarm specialist string the wire through the firewall and the radar unit is hidden under the front bumper. When I start the car, the unit comes on. Everything is hidden. Just another idea to throw out at you! :~)
drew2.7T is offline   Reply With Quote
Old 03-11-2004, 10:39 AM   #4
slimmn
Account #: 51550
Default Very nice Rosty. One question: Is this method better than the one using a spare fuse from the fuse
box (on the driver door side of the dash) and then wiring it along the A pillar? Just curious. Thanks.
slimmn is offline   Reply With Quote
Old 03-11-2004, 11:00 AM   #5
FlyingWombat
Account #: 56796
Default What year audi is this? Will this work with a 99'?
1999 A6 Avant
Ronal R41
Pirelli Pzero Nero 235-45-R17
"All I want for Christmas is a PES G2"
<br/>
create your own personalized map of the USA
or write about it on the open travel guide
FlyingWombat is offline   Reply With Quote
Old 03-11-2004, 11:44 AM   #6
AudiA6Newbie
Account #: 66637
Default Audi never offered a hard-wired radar detector as an option did they? . . .
My '98 A6Q that I bought used, has a hard-wired detector that is absolutely seamlessly installed. The panel with the indicator lights blends in perfectly with the rest of the overhead plastic.
Maybe dealer installed option in certain states?
AudiA6Newbie is offline   Reply With Quote
Old 03-11-2004, 12:25 PM   #7
coop19
Account #: 60116
Default go wireless
or just get one of these and save the time!
<b><a
coop19 is offline   Reply With Quote
Old 03-11-2004, 12:47 PM   #8
Mitch S6 Avant
Account #: 70048
Default Wireless detectors typically don't have the sensitivity/range of corded...
Old 03-11-2004, 02:05 PM   #9
coop19
Account #: 60116
Default Re: Wireless detectors typically don't have the sensitivity/range of corded...
True. I have to say so far I am impressed. I have never tried the V1 though so I may be missing something. I found some reviews for those who may want to think about one. I have a friend who can get K40 the whole thing for about 800 if we buy 6 of them.[list][*]http://www.shop.earthlink.dealtime.c...it=Go%3C%2FBUT
<b><a
Old 03-11-2004, 02:12 PM   #10
RostyVyg
Account #: 47928
Default Saves the pain of tucking the wire under...
the windshield molding, taking off and re-installing the A-pillar cover and pulling it through to the fuse box. And if the suction cups fail, the wire attached to the mirror will hold the RD as a "safety string". Otherwise the RD will just fall on the dashboard or your laps pulling the cord from underneath the windshield molding all the way...
643081, 8500, cord, diagram, escort, mirror, number, passport, power, radio, shack, wires
