Transmission re-code Unsuccessful
Old 09-21-2003, 06:11 AM
Eddieonline's Avatar
Default Transmission re-code Unsuccessful
My '99 A6 trans code is 00000. When is try to change it with the vag-com, the new code appears to be accepted, then when I select do-it, the 00000 code reappears. I've tried numerous combinations of the codes listed on the forum, but no permanent changes are made. Any ideas?
Old 09-21-2003, 07:07 AM
PaulW's Avatar
Default Try 00010
On the 3.7 FWD A8, it comes from the factory with 00000, "sport" mode is 00010.
Try it, it might work.
pw
Old 09-21-2003, 09:48 AM
Stoney's Avatar
Make sure the engine is off, key is on.
Old 09-21-2003, 10:08 AM
kitora's Avatar
Default PaulW - You' the man!!!!
I just tried coding my transmission about an hour ago using both 00022 and 00032, but it wouldn't accept it in my car either.
I always thought it couldn't be done either because my car is a '98 or bacause it's a 2.8. It has always bothered me that the car never really downshifted when I wanted it to, and now it does!!!
This is like getting the transmission I always wanted. I just took it for a short spin after recodoing the transmission using 00010, and it works just perfectly. It's amazing what a difference it makes.
Today I'm a happy camper... )
Old 09-21-2003, 11:53 AM
Default Yes you do be da man!!
00010 seems to be the only code I didn't try before, and is the only one besides 00000 that mine will take. Now the D mode shifts as it always should have - no more hesitation as it seemed to be trying to find the right gear, and the tip stays in 1st until I send it to 2nd.
Anybody with a '98 - '99 A6 would do well to do this mod.
Thanks a million Paul!
Old 09-21-2003, 12:49 PM
QCRAZY's Avatar
WOO HOO!! It worked in my '99 too. Last time I tried it didn't take...this time it did<shrugs>
Old 09-21-2003, 02:36 PM
kitora's Avatar
Seriously, this post belongs in stoney's FAQ. Where are you Stoney...?
Old 09-21-2003, 07:19 PM
Stoney's Avatar
Spotted it, thanks!
Old 09-22-2003, 11:23 AM
Default The Official Reply from Uwe
For 1999 (pre drive-by-wire) A6's the only coding values documented by
the factory are 00000 and 00010. Control modules will reject any
values that do not correspond to options actually available in the firmware.
The 2000 and newer cars (drive-by-wire) have a lot more options, and the
chart you're looking at may be for them.
Regards,
-Uwe-
Old 08-07-2007, 10:26 AM
marko681's Avatar
Default Worked well, BUT in reverse the transmission acted really funny...
has anyone else with a 2.8 found this too?
midnightgolfer
9
05-30-2018 08:21 AM
KEGMotorsports
6
12-24-2015 02:06 PM
S4ptld
05-21-2008 11:09 PM
mission
VAG-COM Discussion
12-11-2006 01:46 PM
GHart81
09-21-2003 06:03 AM
Quick Reply: Transmission re-code Unsuccessful
