Old 11-22-2002, 07:56 AM   #1
A6_machine
Account #: 45275
Default Aftermarket HID?
I am considering purchasing an aftermarket HID kit for my A6. I hate that blue bulb crap and want the real deal. I have seen numerous brands online and I want to know what to go with, price/reliability/performance etc. Any feedback would be appreciated.
2000 A6 2.8Q
18" Techrome Helos Bezels
235/40/18 Kumho Ecstra Supra
2000 Kawasaki ZX12R
Micron Serpent Full System
Power Commander III ( dyno's @ 168rwhp )
( Makes up for the lack of speed and power with the 2.8!! )
A6_machine is offline   Reply With Quote
Old 11-22-2002, 08:15 AM   #2
Pete RD
Account #: 5185
Default Contact Achtuning...they have a set of Euro "E" code headlights
for the A6 not equiped with zenons. The lights do not have the amber corner reflectors (clear corners!) and Achtuning has the "silvered" turn-signal bulbs that are amber when activated. The lights are built with a housing for the "city" light rather than having a "corner" light and that may not work with your wiring harness unless some modifications are made. Josh and I took one of my headlights (zenon) out to compare and see if these would be a "plug 'n play" deal with our zenons...they are not, but he will try to get some that are. Achtuning has installed "E" code euro lights on A4/S4s and report that the euro lights are superior to the US versions.
Contact: josh@achtuning or adam@achtuning...he can speak to the changes required to the wiring depending on what light functions you want.
HTH
Pete Dieckerhoff
Pete RD is offline   Reply With Quote
Old 11-22-2002, 08:19 AM   #3
A6_machine
Account #: 45275
Default Re: Contact Achtuning...they have a set of Euro "E" code headlights
I was looking for plug 'n play so that in the event I ever had a warranty issue i could swap them out without messing with any wiring.
2000 A6 2.8Q
2000 Kawasaki ZX12R
Old 11-22-2002, 08:30 AM   #4
Pete RD
Account #: 5185
Default I think in that case you have to use the parking/turn-signal bulb-
holder out of your oem lights along with your 2-element bulb...that's all (again, I think...).
Contact Achtuning...they can give better answers than I.
Cheers,
Pete Dieckerhoff
Old 11-22-2002, 08:35 AM   #5
Pete RD
Account #: 5185
Default FYI...the A6 headlights are not easy to remove! However,
they go back in much easier...but there are some "tricks" involved. The whole operation on a A4/S4 is very quick and easy...but Achtuning can tell you how on the A6.
HTH
Pete Dieckerhoff
Old 11-22-2002, 08:46 AM   #6
A6_machine
Account #: 45275
Default Re: FYI...the A6 headlights are not easy to remove! However,
Thanks for the info Pete...much appreciated!!
2000 A6 2.8Q
2000 Kawasaki ZX12R
Old 11-22-2002, 11:14 AM   #7
TeddyBGame
Account #: 32631
Default Just installed OEM HID housings last night.
Here is what I learned:
They work perfectly!!! What a difference. Between the OEM Halogen and OEM HID wireharnes...it was a pure Plug N' Play!!!
I had an Audi Tech install these last night - after hours. The auto-leveling motors didn't function (expected). We spent 5 minutes re-adjusting the beam - what a difference!!! I also heard that the low-watt HID bulbs can cause a warning light to come on - didn't happen. The Audi Tech did need to remove the bumper to exchange/install these housings. It made it a lot easier to complete the job. In some cases, you do not need to remove/dislodge the bumper to replace the A6 headlight housings (the Audi tech told me that this varies with each A6...go figure).
The one thing that I noticed with all of those HID kits is that they only include 2 of the 3 main components (bulbs and ballasts). What they don't include are the OEM projectors/optics. The optics are key in projecting the light across an even plane. The Audi Tech and he educated me a bit on the subject; he has worked on A6's with HID kits installed and they all have the same problem - the halogen optics do not distribute the light in an even plan. Most of the A4 guys have installed HID kits with the A6 projectors (purchased from the dealer for $200-$300 dollars).
On another note...
I also noticed that the OEM HID projectors can fit perfectly into my Halogen light housings. The only difference is the auto-leveling function (which requires more parts/sensors etc to work - not worth it - in my opinion). I have my original Halogens and another set of HID housings (bulbs, ballasts, optics) that I will tinker with this Winter. Once I move all these HID components to the Halogen housings I'll probably sell them on eBay.
That's my story and I'm stickin' to it!!
PS - I'll post some pix at a later time.
TeddyBGame
As of November 2006:
Accessory Add-ons:
1) OEM winter floor mats
Upgrades:
9) ?
15) ?
Coming soon:
MODifications:
2000, a8, achtuning, aftermarket, audi, b5, b7, deere, ecode, gator, headlights, hid, john, lights, projectoroptic, signal
