Old 12-30-2001, 06:09 PM   #1
wbk
Default April , I have a technical question
one of the postings on the allroad site is from a guy who replaced the rear sway bar on his allroad with a heavier one from an A6. Is changing the rear sway bar only a dangerous thing? Is he screwing up the balance of the car or suspension?
Silver allroad,
Drive low, park high
73 Volvo 1800ES
wbk is offline   Reply With Quote
Old 12-30-2001, 06:32 PM   #2
April
AudiWorld Uber User
Default It's going to make the car a little more tail happy. The car understeers a lot as it is, and
some people would like for it to be more neutral or even oversteering - hence the larger bar. If you make the rear too hard via sway bar and springs, you can create snap oversteer ( transitions very quickly from understeer to oversteer with little chance to correct ). This is most often seen with BMWs, but can happen with almost any car.
Oversteer is fun if controllable - especially in the dry. Hanging the tail out and going around a corner is great fun. Much less fun on city streets and in snow.
The best/ideal set-up for driver enjoyment and fast track times, is to have a car that is neutral and will oversteer or understeer depending on how you modulate the throttle.
You need to decide how much stiffness in the rear/oversteer is enough for you. The A6 platform understeers a lot in stock form, but can be provoked to oversteer if you try hard enough:-) Just the bar is not going to upset the balance a lot. Play in an empty wet parking lot and see what techniques you usually use, and if changing them will make you feel more or less comfortable. If you want oversteer, use a front wheel drive technique called drop throttle oversteer.
April is offline   Reply With Quote
Old 12-30-2001, 07:42 PM   #3
Stoney
Default Which of those drift techniques can be used with a Tip Tranny?
I remember that S6 video with the British reviewer doing 360s after putting the tranny in N.
A6 (C5 platform) FAQ
Stoney's Picture Library
Email: jds@sonolithics.RemoveThisPart.com
2001 A6 4.2L, Sport, Premium, Nemo Blue, Melange Interior
Stoney is offline   Reply With Quote
Old 12-31-2001, 10:25 AM   #4
April
AudiWorld Uber User
Default Tip mode in 3rd or 4th. Use drop throttle technique for FWD cars. Go in fast
start to turn in, back off gas sharply - maybe even stab brakes lightly to unweight rear - when desired angle drift is done, back on gas. Practice on slippery surface to keep speeds down. I like shopping center parking lots in the rain after hours:-)
drop, oversteer, throttle
