Old 04-22-2008, 12:16 PM   #1
Godfather | Jay
Account #: 99226
Default Evolution Racewerks (ER) intercooler install pictures and notes
This is by no means a complete write-up, but I collected a bunch of pics from a past ER install and the ER website as well as my own. Hopefully these will help future DIY attempts. Thanks Drew (BlkBullitt) for the pics and help!!
Give yourself plenty of time (ignore the time estimated on the instructions).
Somewhat odd tool notes:
* plug-in die grinder and metal cut-off wheel
* big Torx attachments. 45mm or 47mm or 50mm I don't remember
* nuts and bolts - the new brackets don't come with nuts and bolts *sigh*
My install pics:
Note: I went from RS4 to ER intercoolers. If your RS4s use an RS4 hard pipe, make sure to get the stock one (thanks Prince at VAST!)
This was pre die grinder... Safety first!! Note: this may not have needed to be cut per the ER picture further down... oh well it was already mangled from the RS4s. Weight savings FTW
Illustrates some plastic cutting done on the inside edge (pics further down show it better):
Action shot. I wish I had pics of cutting with the die grinder. It was like a 4 alarm fire compared to the sparks from the dremel!
Picture to illustrate one of the bigger cuts and a reminder about the bolts. Ignore the RS4 ICs, etc as this is an old picture.
Driver side bolted in. Stock IC bracket was removed (drill out rivets). Horn was remounted behind the IC using the bracket and a purchased nut and bolt.
Passenger side bolted in. Again we removed the stock IC bracket. The AC cannister was remounted using the supplied bracket and some purchased nuts to fit it (the posts). Note that there was nowhere to actually mount this bracket that connected to the A/C cannister. So we chose to zip tie the bracket around a support (it was hollow so no way to drill and use a nut and bolt). We could have drilled a small hole and used a pop rivet... Had to use washers to space the fog light out to keep the back of it from touching the IC.
Quick IAT comparison
PlanetS4's pics with some add'l notes while being installed at WMS - full thread
Note: Went from AWE to ER
AC hose clearance. Another caveat, by jacking up the passenger side of the car and putting the nose into a semi-service position you can slip the IC in and out with ease from underneath rather than trying to muscle it in from the side. (IIRC we found it easier to come in from the top - using the "chair mod" or having someone pull the front out farther)
These markings were from the AWE trim spec
Trimming of AC bracket for pass side. (we removed entirely)
additional driver side trimming
Slight trimming of bumper plate on passenger side only. (similar to what I did, but I trimmed the lip all the way up)
(Note the missing bumper support bolts. I had one less on the driver side IIRC.)
Evolution Racewerks pics (a writeup would be nice!)
Didn't have to cut much somehow. ???
No clue how the lower left bolt spot didn't have to be cut off. Please note that you can't install the lower left bolt even if you don't have to cut it off so you may as well cut it off. Same goes for the driver side bolt, but you don't need to cut there.
Note missing bolt again.
Correct pipe connection.
Godfather | Jay is online now   Reply With Quote
Old 04-22-2008, 12:22 PM   #2
my2000apb MEGABOOST
Account #: 114326
Default very nice write up
my2000apb  MEGABOOST is offline   Reply With Quote
Old 04-22-2008, 12:23 PM   #3
OldSkewS4
Account #: 8238
Default Nice helmet. SA2005 rated? ;-)
OldSkewS4 is offline   Reply With Quote
Old 04-22-2008, 12:25 PM   #4
Steve_Ag Arrow
Account #: 5987
Default good info, thanks.
97 A4 2.7T OEM RS4 Widebody 6-speed
01 S4 2.7T Imola Avant 6-speed
05 Allroad 2.7T 6-speed (dad's tow car)
Steve_Ag Arrow is offline   Reply With Quote
Old 04-22-2008, 12:27 PM   #5
Godfather | Jay
Account #: 99226
Default No clue. haha
Old 04-22-2008, 12:28 PM   #6
TS4F
Account #: 110527
Default Looks like 5 degrees cooler IATs than with the RS4 ICs
What will that mean in terms of hp, torque, or whatever?
</noob>
Before vB I used to have a worthwhile signature
TS4F is offline   Reply With Quote
Old 04-22-2008, 12:31 PM   #7
S4lorn
Account #: 101068
Default My off the cuff shows about 30 degree delta @ 6.5 K between the two .Should make a difference
S4lorn is offline   Reply With Quote
Old 04-22-2008, 12:39 PM   #8
Godfather | Jay
Account #: 99226
Default Bigger than 5 degree delta difference at least during a FATS run. I
don't know what it will mean in HP/TQ.
I can't wait to do some multi-gear tests to see if they remain as efficient.
Old 04-22-2008, 12:52 PM   #9
Nigel (no more S4)
Account #: 77913
Default I think this summer is going to be the real litmus test for this IC's
Everyone has has awesome logs of IAT delta throughout the winter months, but now lets see how they perform in 80+ deg ambients
done
Nigel (no more S4) is offline   Reply With Quote
Old 04-22-2008, 01:16 PM   #10
DVS27t
Account #: 8981
Default I had them last summer and they were fine....
2001.5 NOGARO BLUE Audi S4 6 speed stg3 (16,000 miles)
3.11 FATS on the 104 octane w/ full exhaust and 400cell cats @ 22psi. 463whp/433wtq
2000 Light Silver Metallic A4 Avant 1.8tqm (185,000 miles and runs like a clock) chip only (91 oct), 165whp/195wtq
::SOLD::2000 A4 PES T28/Moss sauce powered 333hp 91 octane (sold)
Fast Intentions Wide Mouth DPs and custom 3.5" exhaust on my 2001.5 Stage 3 S4
RIP
DVS27t is offline   Reply With Quote
a4, audi, awe, diy, er, evolution, front, install, intercooler, intercoolers, mount, prices, racewerks, rs4, s4, writeup
