Old 10-13-2007, 07:08 PM   #1
The_Jerbel (Jordan)
Account #: 112060
Default Anybody taken out their fuel pump before?
How the F does the baffle housing come out of the fuel tank without the special tool? Any tips? Thanks
Jordan
custom shift knobs>
more shift knob pics>
Jordan
2000 S4 - VAST stage 3+ HB, K04's, VAST hi-flow fuel pump, green giant injectors, Ported and polished exhaust manifolds, piggie pipes, RS4 Airbox, MAF, and accordion, VAST stage 3 ceramic organic hybrid clutch and RS4 PP, poly snub, RS4 motor and trans mounts, innovate wideband AFR gauge, low temp after-run switch, Bailey sport DV's, Milltek 3" exhaust, neuspeed rear sway bar, Eibach sport pro, Bilstein sport, E-code HID, 235/40/18 Kumho Ecsta SPT, VAST MBC and adjustable TCD, RS4 intercoolers, RS4 front bumper and grill, Custom backlit bird's eye maple shifter with JHM solid short shift and delrin bushings and rebuilt shifter linkage
The_Jerbel (Jordan) is offline   Reply With Quote
Old 10-13-2007, 07:11 PM   #2
visintainer [vis]
Account #: 90752
Default i fit both my hands in the tank and twisted the bitch out. i tried to make a tool out of some
steel but could not get it to work well
MIKE SPOKANE, WA - PIGGIE POWERED
MY S4 WEBSITE/CLASSIFIEDS - E-MAil ME - TORQUE SPECS - PART #s - NOOBs CLICK HERE
Q U A T T R O W O R L D F T W
visintainer  [vis] is offline   Reply With Quote
Old 10-13-2007, 07:14 PM   #3
The_Jerbel (Jordan)
Account #: 112060
Default Thanks man, did you push down as you twisted, or will it twist out without...
pushing down? Also, what part of the baffle did you grab? Thanks again
Jordan
custom shift knobs>
Jordan
Old 10-13-2007, 07:14 PM   #4
Scottyt
Account #: 116074
Default OT: Love your car btw
Scottyt is offline   Reply With Quote
Old 10-13-2007, 07:16 PM   #5
visintainer [vis]
Account #: 90752
Default pretty sure i was pushing down. been a few months.
Old 10-13-2007, 07:17 PM   #6
The_Jerbel (Jordan)
Account #: 112060
Default Thanks Scotty and Vis :)
custom shift knobs>
Jordan
Old 10-13-2007, 07:25 PM   #7
visintainer [vis]
Account #: 90752
Default be cafeful not to disconnect the filler hose out of its place holder clip.
i got mine out of place when installing my 044 pump and it will prevent filling up your tank. also be careful of hose placement so the hoses don't prevent the sender float from moving up and down to read the level.
Old 10-13-2007, 08:03 PM   #8
Ski05751
Account #: 3594
Default This is the tool I made.
Just a piece of 1/4" rod with a nut on the end that is bent to fit the notches of the basket. To make sure the nut does not fall off in the tank, hit the nut with a hammer and lock it to the rod.
The nut catching the notch in the backet and the leverage of going around the FP is what makes this work so well. Works equally well installing the new FP.
I tried for half an hour using my hands to get the FP out to no avail. Made this tools and 5 seconds later the FP was out.
Its not pretty but worked very well and didnt cost anything since I had the piece of scrap rod laying around.
-Wes
make fuel pump removal tool
Ski05751 is offline   Reply With Quote
Old 10-13-2007, 08:34 PM   #9
Cypher2k
Account #: 86254
Default its keyed. you can drop it in anyway you want but it only snaps back in one postion only.
Cypher2k is offline   Reply With Quote
Old 10-14-2007, 08:48 AM   #10
The_Jerbel (Jordan)
Account #: 112060
Default Yeah I figured that. So when you put it back in you probably have to...
line it up, push down, and twist clockwise to lock it in hey?
custom shift knobs>
Jordan
