Old 08-20-2006, 11:56 AM   #1
BLK01S4::HB B!SH
Account #: 52597
Default Homebrew tiptronic logs .. inquire within please :) BWW
Ok so heres what I got:
Apexi AVCr- Spike 25 taper to 23 at redline (Sorry EdyJun I know you wanted to see an MBC buyt I am determined with this EBC!)
RS6 turbos PP, C
440c Greentops @ 4 bar
R$4 fuelpump
90mm JBuhen MAF
R$4 Airbox w/holes
and all the other goodies you guys know about already ..
OH it was 88deg F outside I have a hard time hitting the sweet spot of 280g/sec when its really hot out and 100% humidty.
On to the logs!
From the raw actual data I see the car applying more fuel as the correctload values of the car decrease on gear change. This may explain why it gets so rich in 4th gear. I am going to move the value for decreasing loads from its default 100% to something like 70.3% see how it goes. I also going to back down increasing loads a tad and leave primary fuel where its at. In the actual data at the start of this log its right at .86 for a bit.
Stage III Tip : ??? FATS (Race Gas) 3.43 Average Pump gas
Fastest Tiptronic! ET: 12.259@118.25mph :)
"Turbos are usually the cheapest/easiest way to add power - Posted by: Corrado79 on 2008-05-21 13:22:49
"Amazing that he could maintain a wedgie and talk out of his ass at the same time. That's one skill he CAN lay claim to. - Skydive@W?? 2007-12-18"
"good I just added you to my " bitch " VIP list ." -Professional customer service - SIMPPLY@WMS 2007-12-17
"i tried the propane file on butane and it blew my ****ing grill up." - mjtaylor::pipedream 2007-08-23 14:21:46
"It takes a problem which we don't have and doesn't even solve it" - Mirror|rorriM on 2006-09-26
"but yeah you want open loop when you go wot ;-)" - PiggieSmalls on 2006-11-10
BLK01S4::HB B!SH is offline   Reply With Quote
Old 08-20-2006, 12:03 PM   #2
BLK01S4::HB B!SH
Account #: 52597
Default Oh on another note
I was having a problem with the car running really lean. So I unplugged the ECU overnight .. Problem solved now its rich and this log was taken after driving approx 50 miles on the highway beating the piss outa it.
Old 08-20-2006, 12:23 PM   #3
PSmalls::AnalRetentiveNumbNut
Account #: 112331
Default IMO, this whole g/s sweet spot thing is overrated. Just make sure you're above 200 g/s at 100% TP.
You sure it was only 88F? Your car triggered EGT enrich...or so it looks. Your timing is horrible, your CFs are off the Mark P charts, your IATs skyrocket.
WTF is the explanation for 199% increasing loads? That sounds crazy.
Get a wideband and check your AFR before anything else IMO. I haven't seen many cases of EGT enrich + crappy timing like that + CFs like that + 02 voltages like that, makes me think you're actually pretty lean until the ECU tried to save your ass.
PSmalls::AnalRetentiveNumbNut is offline   Reply With Quote
Old 08-20-2006, 01:43 PM   #4
EdyJun
Account #: 48484
Default Can you do another Log but w/ 19-20 PSI across and only in 3rd (FATS)?
I like to see if it will change ur o2 reading and flat it out a bit more?
I think your car is a little weird.
Edy
2000 Audi S4 STG 3
FATS = 3.66 w/ 91 oct
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 08-20-2006, 01:58 PM   #5
BLK01S4::HB B!SH
Account #: 52597
Default and leave the lemmiwink settings alone?
$$$$$$$$$$$$$$$$$ = !@$#!#!!@&amp;%!
Old 08-20-2006, 02:34 PM   #6
Imolavirus@BuehnEngineering
Account #: 33927
Default not going to run very well if you don't change them......
you'd almost have to rutune just to get a log of 19-20psi.
-Jacob
<big>Items For Sale</big>
Old 08-20-2006, 02:45 PM   #7
eigenvector
Account #: 103335
Default 2nd..
(Audi)(S4)(01.5)(Silver)(90k)(Stage 2+)
(GIAC)(710N)
eigenvector is offline   Reply With Quote
Old 08-20-2006, 03:11 PM   #8
BLK01S4::HB B!SH
Account #: 52597
Default thats what I thought I have a zentronix on the way tired of playing with this thing.
Old 08-20-2006, 03:46 PM   #9
EdyJun
Account #: 48484
Default The only thing i would chang would be chn 2 - set it to 100%. However i dont think its needed.
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 08-20-2006, 04:05 PM   #10
Account #: 33927
Default why wouldn't ch. 8 or 10 change?
-Jacob
