Old 06-02-2006, 09:49 AM   #1
Ah10@WMS
Default Ah10 needs some help from AVCR master out there!
I installed the AVCR last weekend, and been trying to get it work the way it should but have some issues.
here is some background, all the wires hooked up correctly, since i can see boost, rpm, throttle and speed. and on the vac lines i did used all three from N75, wastegate to COM, boost to NO and ambient temp to NC and i have checked like 4~5 times all the lines are secured.
Here is the symptoms, boost is not as stable as i was running MBC alone, it would spike to where i set it to, then as rpm goes up, and it starts to taper and it would bounce up and down in the range of 2~3psi. *Oh i have done the learning part, let the unit learns itself on the duty cycle*
Here is the setting i am shooting for:
3k 1.55kg/cm^2
4k 1.55kg/cm^2
4.5k 1.50kg/cm^2
5k 1.50kg/cm^2
5.5k 1.45kg/cm^2
6k 1.45kg/cm^2
6.5k 1.40kg/cm^2
7k 1.40kg/cm^2
I am trying to achieve 22psi spike and taper to 20psi!
Please help Poor Ah10 on this one!
Thanks a bunch
WMS: 818-997-6500 ASP:856-772-9500
|| ASP Custom Tuned Stage 3 || 710P || Piggie DP || ASP 89mm Truedual || ASP TSB || APR Boost Gauge || RS4 Grille ||
|| AWE Intercooler || C M Stage 4, 6 puck & LWFW || ASP Motor Mount || RS4 Tranny Mount|| StaSIS Motorsport Ohlins ||
|| 18" Work W-ITS 901 || 245/35/18 ContiSport3 || Ecode || Modded RS4 Bumper || StaSIS Motorsport Alcon 6pot 355 ||
WMS Stage III: 3.54 fats on Pump 3.25 fats on Race gas both runs were on pump file
3.06 on East Coast Pump Gas/Race File
2.93 on East Coast Pump Gas/Race File in 40f weather
Ah10@WMS is offline   Reply With Quote
Old 06-02-2006, 10:15 AM   #2
k04/rs6north
Default ygm
2001.5 Nogaro S4
2002 Black Allroad 6spd
RIP Matthew Ammon aka O.W. Kenobi
k04/rs6north is offline   Reply With Quote
Old 06-02-2006, 11:23 AM   #3
Ochlockonee
Default You're not using an injector wire for tach signal are you? If your injectors go over 100% the avc-r
cuts your boost.
What I do is observe the actual duty cycle of the solenoid and try to look at the boost gauge at the same time. Once I get an idea of what solenoid DC needs to be for each RPM range, then I adjust in a duty cycle curve. If you can get DC within ~8% of where it has to be for each rpm range to give the desired boost, the controller learns a lot faster. You don't have to dial in a DC curve if you don't want to, it will still learn without that, I just got impatient.
"No, a flux capacitor is not compatible with a ham sandwich."
Ochlockonee is offline   Reply With Quote
Old 06-02-2006, 12:29 PM   #4
illbill
Default Is the auto-learning curve resolution better than the 500rpm increment you can enter manually?
I'm looking at this controller to replace my profec B. My wastegate is a pos and needs a controller that has variable DC over the rpm band. My only worry is that the 500rpm res is too coarse, I ideally would like something that has a 200rpm res. If the autolearning fills in those "gaps" I would probably jump on this controller sooner than later. TIA
shawn
<a href="http://profile.mygamercard.net/illbill+kun">
illbill is offline   Reply With Quote
Old 06-02-2006, 01:15 PM   #5
Ochlockonee
Default Yes, the auto curve is sweet. When I'm looking at duty cycle it moves quickly
and also adjusts dc in increments smaller than 1%. If I roll on the throttle in 6th where rpms climb slower, you can see it making a million adjustments within a 500 rpm window.
Old 06-02-2006, 01:27 PM   #6
illbill
Default awesome, exactly the answer I wanted to hear.
The profec B only has one wastegate DC setting, and it uses it across the whole rpm band and across all gears. 42% at 3k is 21psi, but only 14psi at 7k. Makes for terrible boost curves.
Old 06-02-2006, 01:51 PM   #7
Ah10@WMS
Default These are the wire i used, 35(Yellow/blue), 37(green/blue) and 54(white/blue)
|| AWE Intercooler || C M Stage 4, 6 puck &amp; LWFW || ASP Motor Mount || RS4 Tranny Mount|| StaSIS Motorsport Ohlins ||
Old 06-02-2006, 02:12 PM   #8
Ah10@WMS
Default Or do you think the solenoid valve itself would go bad?
