Old 05-29-2006, 05:24 PM   #1
Jason Trumpio
Default Stasis motor mounts = worth every ffing penny
I have been putting off the install because the last time I swapped the mounts I went through enough hell to wonder if I was Judas, betrayer of Christ in a previous life.
Too bad I fell sucker for the ECS "OEM RS4" mounts at that time. I finally got sick of the popping, clanging, and bumping, of my OMG GENUINE RS4 MOUNTS!!1 and decided to suck it up. This time it took me about an hour per side.
I must say, I am impressed. NVH is minimal compared to what I was expecting. There is a little additional vibration at idle, most of it felt through the steering wheel, but again, it's far less than what I've experienced in most American cars You're just "aware" of the "presence" of a running engine in the car.
But any NVH is totally offset by the fact that when you stab the throttle, the car responds instantly and accelerates. It doesn't lift the drivetrain up 6 inches and then accelerate, and then clunk when you lift. Shifting is so much more pleasurable (I installed my ASP TSB and REAL RS4 trans mounts yesterday). Matched-rev downshifts feel much more accurate.
All in all, it may not be everybody's cup of tea, but I consider the S4 drivetrain rodeo business worse NVH than a little vibration. At cruise, I didn't notice any additioanl NVH.
Anyways, if I knew this the first time around, I would have ponied up the extra green the first time instead of learning the hard way.
2000 S4 w/ some stuff
Jason Trumpio is offline   Reply With Quote
Old 05-29-2006, 05:55 PM   #2
archimense
Default Where do you buy them? They aren't listed on the Stasis site.
2001.5 Audi S4 Stage 3
Stasis Tracksports 700/800 and 4:1 centre diff
CPP front upper arms, tie rod ends, rear end links, rear toe links
Neuspeed 22mm Rear Sway
ASP Tru Dual downpipes and exhaust
Custom chip with 60lb injectors and 85mm MAF
55w Xtec HIDs
etc etc etc
archimense is offline   Reply With Quote
Old 05-29-2006, 05:58 PM   #3
Mike2kS4
Default Nice review. Thanks for the info :)
Old 05-29-2006, 06:13 PM   #4
Jason Trumpio
Default Just give them a call...
Old 05-29-2006, 06:33 PM   #5
Milpitas2.7T
Default You log it at all, to see if there is added timing correction? And I really do hope
these last longer then the initial Design-IT's, we absolutely need an alternative
Tory
Milpitas2.7T is offline   Reply With Quote
Old 05-29-2006, 06:37 PM   #6
forced2induce
Default 2nd. they look delicate...not for the tristate i'd imagine
forced2induce is offline   Reply With Quote
Old 05-29-2006, 06:56 PM   #7
Ochlockonee
Default 2nds
"No, a flux capacitor is not compatible with a ham sandwich."
Ochlockonee is offline   Reply With Quote
Old 05-29-2006, 07:14 PM   #8
Jason Trumpio
Default I'm probably the only S4 owner without a vag-com, LOL
The car has always run great and I've never had the need for one, so it's been low on the priority list.
The recto-dyno didn't discern any difference in performance, but it's been known to lie before.
These mounts I installed DO have some type of polymer isolation, so I doubt there would be any false knock as a result.
Old 05-29-2006, 07:15 PM   #9
Jason Trumpio
Default Actually I've had 4 sets of tires on them now, and they still run true
Despite my expectations for at least one bent wheel by now.
Old 05-29-2006, 07:28 PM   #10
Jason Trumpio
Default some more pics inside...
Most of these are with the smaller toyos. The new KDW2's are a tad wider.
water spots!
I think the car looks better with these monsters on it:
But I haven't had a good photo op with those bigger tires.
2003, 27, audi, audiworld, b5, engine, install, jason, motor, mount, mounts, s4, stasis, trumpio, worth
