New! Use your Facebook to securely log into this site, click logo to login
Old 05-28-2006, 12:22 PM   #1
bla4ck
Account #: 91659
Default water/methanol injection BT: i know some of you use the Aquamist set up. how about Boost Cooler?
is that any good? whats your experience with either system?
Boost Cooler
looks like the Boost Cooler Stage-2 MAF would be the best solution.
sorry i haven't STFA so i'm not sure if this has been discussed.
bla4ck is offline   Reply With Quote
Old 05-28-2006, 01:04 PM   #2
ed@4induktion.com
Former Vendor
Account #: 17991
Default we've used that kit on the 1.8T ....works well and the kit is complete / easy to set up
ed@4induktion.com is offline   Reply With Quote
Old 05-28-2006, 01:41 PM   #3
lemieux@curbside
Account #: 47312
Default tj: i'm in Falls Church VA 'till tomorrow .. are you closed all long weekend ? maybe i can stop by
and say hello !
"it's a B5 S4 ,it may break down, but its far enough ahead, by the time its fixed, you still haven't caught up." -best line i've heard
AUDI B5 S4 detail info (pdf file) that everyone should read and have saved on his computer
AUDI B5 RS4 study guide detail info (pdf file)
FATS database
VAG-COM LOCATOR
ASP Hands down the "BESTEST" tuner out there.
lemieux@curbside is offline   Reply With Quote
Old 05-28-2006, 02:11 PM   #4
bertworks(dan@jhm)
Account #: 99112
Default that kit is from snow performance and works great. i am going to order it soon but my buddy...
has it on his high hp vett right now and is working out great for him. i need it since these damn temps in cali are so hot during the summer months, the only time you can go to the track is at night and im hoping with a water/methonal set up my iat's will be cold enough to help with power on the hot days.
2000 s4 jhm/vast stg gt
2001.5 a6 4.2(in work)
bertworks(dan@jhm) is offline   Reply With Quote
Old 05-28-2006, 02:15 PM   #5
elijahallen
Account #: 71531
Default I used that kit on my S2 and past S4 and it worked very well but the tank needs to be twice that...
size for track use.
Elijah
Vast stage 3+ fueling, K04/RS6 turboed work truck/track whore/crash slut.
<br/>By elijahallen, shot with u40D,S500,uD500 at 2009-02-03
elijahallen is offline   Reply With Quote
Old 05-28-2006, 02:18 PM   #6
bla4ck
Account #: 91659
Default well for track use, i figure i'd just refill it after each session
Old 05-28-2006, 03:12 PM   #7
SmokinS4™
Account #: 18942
Default That is what I do, it worked well the one time I tried it.
how's that for a short signature
Stg4 S4.
SmokinS4™ is offline   Reply With Quote
Old 05-28-2006, 03:18 PM   #8
SmokinS4™
Account #: 18942
Default Or get the trunk mounted 7qt tank
I wish I saw this stuff before I went with Aquamist and saved myself $300-400
Stg4 S4.
Old 05-28-2006, 03:18 PM   #9
rojodosformula::red
Account #: 71729
Default I have one. Works good. You'll need the one way check valve or a solenoid....
Funkweasel suggested a 100cc accumulator as well. I tapped into the stock washer bottle. I usually go though a gallon of water per every 1.5 -2 tanks of gas. I got the boost variable controller and it's very accurate. The quick disconnects for the tubing are very cool as well. A very nice kit and super easy to install. The pump and jets are significantly bigger than the aquamist set up. The auquamist pump is about the size of a fist while the boost cooler is an rv shower pump about the size of a starter. If you have a 2000 s4 you can pop off the steering pump cover and mount it on a bracket right above the connectors. Fits perfectly under the hood and is easily accessed.
Formula red NSX-T
Tein Mono flex coilovers
NSX-R chassis bars
Dali SS exhaust
Dali ram air/ Uni filter/ SS shifter/ Leather Sparco Milanos
Volk GT-P wheels
CF NSX-R spoiler
Viva la please use the classifieds!
Riebes Auto Parts in Loomis, CA can suck it. Thanks for the help bitches.
rojodosformula::red is offline   Reply With Quote
Old 05-28-2006, 03:23 PM   #10
SmokinS4™
Account #: 18942
Default What are you using for a mixture?
Personally, I have been just using standard (cheap) blue windsheild washer fluid
Stg4 S4.
audi, injection, methanol, vast, water
