Old 05-19-2006, 10:36 AM   #1
jwolf::ASP S3
Default help me figure out if my n75 is going bad...logs inside
trying to figure out if my n75 is causing my low boost problems. i pressure tested the car about a month ago and everything looked good. Im only making 16psi at redline. Sometimes i spike to 24 and taper down, and sometimes i spike to 20 and taper down. Im not throwing any codes and i have new 710Ns. I logged block 114 but im not sure how to interpret n75 duty cycles. TIA Fats times are also down to 4.0-4.1 when they used to be 3.5-3.6
ASP DPs w/ AWE Twin1 Exhaust
Southbend Stg5 Feramic clutch
AWE LWFW
H&R Bilstein
Samco
EVO intake
Neuspeed SS
APR Snub
RS4 MM
RS4 Front Bumper and grille
SSR Comps, Pilot cup sport:Track
OZ SL Custom Paint, Nitto 555:Street
3.29 FATS on 100oct
jwolf::ASP S3 is offline   Reply With Quote
Old 05-19-2006, 10:42 AM   #2
Ochlockonee
Default If you have a boost leak your maf #s and o2 values would be high while boost is low.
"No, a flux capacitor is not compatible with a ham sandwich."
Ochlockonee is offline   Reply With Quote
Old 05-19-2006, 11:05 AM   #3
EdyJun
Default Are you running TCD and MBC? can we get more logs?
2000 Audi S4 STG 3
FATS = 3.66 w/ 91 oct
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 05-19-2006, 11:08 AM   #4
jwolf::ASP S3
Default running TCD, no MBC. What would you like to see?
AWE LWFW
H&amp;R Bilstein
Samco
EVO intake
Neuspeed SS
APR Snub
RS4 MM
3.29 FATS on 100oct
Old 05-19-2006, 11:58 AM   #5
Flyboy
Default Have you ever adjusted your N75?
I'd expect the N75 duty cycle to increase as the ECU tries to increase the actual boost toward requested.
Have you tried disconnecting the ECU and then logging that stuff after it has been reset? Might be interesting to see what happens when the system has a fresh look at the conditions.
www.MyAudiS4.com/vast-sucks (Updated: 20 Jan 2012)
Stock -> APR Stg1/2 -> GIAC Stg2 -> APR K04 Stg3 -> EPL TiAL 605 -> V̶A̶S̶T̶ EPL/Frankenturbo F4H
Flyboy is online now   Reply With Quote
bad, disconnecting, mbc, n75
