Old 05-13-2006, 07:53 PM   #1
Mike2kS4
Default PSA: Bleed your clutch
I noted my pedal was acting a bit funny, engaging lower than normal so I decided to bleed the clutch.
What joooo need:
Cold engine
9mm 1/4" drive DEEEEP socket
1/4" rat****
What joooo need to do:
Unbolt and move your coolant tank.
reach down in there and put your ratchet/9mm socket on the clutch slave cylinder.
Either,
A: pump up your brake bleeder with new fluid and loosen the fitting and let the fluid dribble for a while.
or
B: Have someone pump the clutch down/bleed/pump/bleed/you get the picture.
anyhow, If you haven't done it in 2yrs... I'd strongly suggest it.
Old 05-13-2006, 07:57 PM   #2
BLK01S4::HB B!SH
Default I lack that pedal :P
Stage III Tip : ??? FATS (Race Gas) 3.43 Average Pump gas
Fastest Tiptronic! ET: 12.259@118.25mph
"Turbos are usually the cheapest/easiest way to add power - Posted by: Corrado79 on 2008-05-21 13:22:49
"Amazing that he could maintain a wedgie and talk out of his ass at the same time. That's one skill he CAN lay claim to. - Skydive@W?? 2007-12-18"
"good I just added you to my " bitch " VIP list ." -Professional customer service - SIMPPLY@WMS 2007-12-17
"i tried the propane file on butane and it blew my ****ing grill up." - mjtaylor:ipedream 2007-08-23 14:21:46
"It takes a problem which we don't have and doesn't even solve it" - Mirror|rorriM on 2006-09-26
"but yeah you want open loop when you go wot ;-)" - PiggieSmalls on 2006-11-10
$$$$$$$$$$$$$$$$$ = !@$#!#!!@&amp;%!
BLK01S4::HB B!SH is offline   Reply With Quote
Old 05-13-2006, 08:00 PM   #3
Mike2kS4
Default You'd better work on that man.
My other car could have had a DSG, but it wasn't good enough for me, or the wife.
FWIW, DSG is brilliant and the best ATX I have ever driven... but comes short.
Old 05-13-2006, 08:04 PM   #4
ZephyrS4
Default I've wondered about that. I've had the car 3 years and have never done it.
It has started to make a little groaning noise when letting it out slow.
ZephyrS4 is offline   Reply With Quote
Old 05-13-2006, 08:09 PM   #5
Mike2kS4
Default Just do it...
It's a bit of a reach. Make sure the Engine is cold. My impatience and high pain tolerance resulted in 2nd degree burns on my forearms, lol.
Old 05-13-2006, 08:10 PM   #6
ModifiedA4
Banned
Default you forgot the standard clutch bleed disclaimer...
the bleeder is plastic, and easy to break.
ModifiedA4 is offline   Reply With Quote
Old 05-13-2006, 08:15 PM   #7
Mike2kS4
Default Thanks for the disclaimer ;)
Mine has lasted since 1999.
Old 05-13-2006, 11:23 PM   #8
BLK01S4::HB B!SH
Default I have a product just for you its called
"Hot .. Not" a sleeve that goes over your arm for doing nutty jobs like we do =] works well!
Old 05-14-2006, 07:34 AM   #9
Silver Streakin'
Default and the other one
(if you do it from below on a lift)
if you don't move out of the way, the fluid will either end up in your arm pit or on your shoe.
-Jeff
2001.5 A4 1.8TQMSCC with APR SIII, EVO FMIC, Stoptech-less, STaSIS Tracksports 600F/750R
ACNA MidOhio video
Montreal race school and PDA Pocono video
Silver Streakin' is offline   Reply With Quote
Old 05-14-2006, 09:19 AM   #10
ModifiedA4
Banned
Default lol, exactly!
2003, 27t, 80, a3, a4, audi, b6, bleed, bleeding, clutch, quattro, s4, tt
