Old 02-28-2006, 05:57 AM   #1
Captain Matt, I be
Account #: 26545
Default Bosch / Volvo "Green Giant" fuel injector info:
It's been suggested that the new injectors AWE is using are the Bosch "Green Giant" injectors, commonly used as OEM parts in the Volvo R cars.
Here's the info i've been able to find on this injector:
Bosch part number 0 280 155 968
310.0 g/min flow @ 3 Bar
12.0 Ohms resistance
EV6 design type
Dual spray
Long body
Compare this to the commonly used Bosch / Ford Motorsport "Greentop" injectors:
Bosch part number 0 280 150 558
Ford Racing part number M-9593-F304
326.8 g/min flow @ 3 Bar
14.5 Ohms resistance
EV1 design type
standard body
Both injectors use Bosch 9 122 067 011 connector types.
I'll post back if i can find more detailed specs on spray patterns.
Captain Matt, I be is offline   Reply With Quote
Old 02-28-2006, 06:03 AM   #2
[badmoon]
Account #: 43125
Default Ho Ho Ho...
I think these may be the same injectors Sportec was trying to pawn off on me and my friend a year ago.
[badmoon] is offline   Reply With Quote
Old 02-28-2006, 06:04 AM   #3
lemieux@curbside
Account #: 47312
Default u think these will work ? :
i don't know how/if they fit tho'
@ 4.5 bar maybe .. i'm lost.
"it's a B5 S4 ,it may break down, but its far enough ahead, by the time its fixed, you still haven't caught up." -best line i've heard
AUDI B5 S4 detail info (pdf file) that everyone should read and have saved on his computer
AUDI B5 RS4 study guide detail info (pdf file)
FATS database
VAG-COM LOCATOR
ASP Hands down the "BESTEST" tuner out there.
lemieux@curbside is offline   Reply With Quote
Old 02-28-2006, 06:06 AM   #4
Captain Matt, I be
Account #: 26545
Default they should - call racetronix for spray pattern and connector info though.
Old 02-28-2006, 06:08 AM   #5
lemieux@curbside
Account #: 47312
Default or these @ 4 bar ..
FATS database
VAG-COM LOCATOR
Old 02-28-2006, 06:11 AM   #6
PSmalls::DoggieStyle
Account #: 69223
Default Of course they'll work. My car seems to be evidence of this.......
However, I'd probably go with the 42# ones if I did it all over again. That way, I could run lower fuel pressure and still have more headroom. This only matters if you are running over 1.5bar and/or hybrid turbos IMO.
Old 02-28-2006, 06:11 AM   #7
lemieux@curbside
Account #: 47312
Default these look look a bit like the stock ones ..
FATS database
VAG-COM LOCATOR
Old 02-28-2006, 06:12 AM   #8
Captain Matt, I be
Account #: 26545
Default try these @ 3 Bar:
theyre flow matched sets and ive always wondered how they'd work - you know you wanna be a pioneer
Old 02-28-2006, 06:15 AM   #9
lemieux@curbside
Account #: 47312
Default but 525cc @ 3 bar is a bit much tho' ..i'm looking ( i think) for around 490-500 cc/min
FATS database
VAG-COM LOCATOR
Old 02-28-2006, 06:19 AM   #10
lemieux@curbside
Account #: 47312
Default the 42-s on 4 bar should be ok u think?
FATS database
VAG-COM LOCATOR
a4, bosch, breakdown, ev1, flow, fuel, giant, giants, green, injector, injectors, matched, s4, top, volvo
