Old 01-24-2006, 09:14 AM   #1
FixedWing
Account #: 66531
Default Ohlins dampers - this time with hemispherical bearings.
Out on Saturday, back on Tuesday. Not bad service!! Thanx Ohlins USA.
These need slightly different spacers to fit the lower suspension mounting bolts. Jason just this second called me to tell me that STaSIS had already custom made a set of stainless steel spacers and was sending them out today. I didn't even have to ask! Thanx Jason and STaSIS.
I shall be very interested to see how the hemispherical bearings handle, feel and sound -- and last. :-)
Stephen
FixedWing is offline   Reply With Quote
Old 01-24-2006, 09:18 AM   #2
golfrsi
Account #: 46784
Default I wonder if it would be in your best interest to run a thin bead of silicone along the
joint between the outer race and the aluminum body since there is no more movement between those? Obviously there will be no expansion problems between both steel pieces, but the difference betweent he steel and the alum. seems to be were your having your issues. If it is ralated to moisture seeping in there a sealer should/would solve that issue
golfrsi is offline   Reply With Quote
Old 01-24-2006, 09:21 AM   #3
Pat-SoCal
Account #: 16079
Default Cool, enjoy!
Pat-SoCal is offline   Reply With Quote
Old 01-24-2006, 09:22 AM   #4
S4Poor@Curbside
Account #: 98473
Default You got a Hemi in dar'?
S4Poor@Curbside is offline   Reply With Quote
Old 01-24-2006, 09:24 AM   #5
FixedWing
Account #: 66531
Default They are not a press-fit. They are held in by a clip. So there is room for expansion.
Plus they are stainless steel.
Stephen
Old 01-24-2006, 09:25 AM   #6
FixedWing
Account #: 66531
Default Over my dead body. :-p
Old 01-24-2006, 09:25 AM   #7
FixedWing
Account #: 66531
Default Thanx Pat. I will try. :-))
Old 01-24-2006, 09:36 AM   #8
BiturboBoy_V2.0_S3--
Account #: 13456
Default hope it all works out. stainless should be good to go...but damn new england salted roads!
BiturboBoy_V2.0_S3-- is offline   Reply With Quote
Old 01-24-2006, 09:38 AM   #9
FixedWing
Account #: 66531
Default No kidding ... just went out and it was piled on after just a two inch snow fall. :-/
Old 01-24-2006, 09:40 AM   #10
Account #: 13456
Default you know in california...15% of registered cars have over 200K miles and are 10+ years old?
never would happen here. :-(
