Old 01-19-2006, 10:34 AM   #1
EdyJun
Account #: 48484
Default What do you guys think about using the VAG to adj the Xenon Headlights?
I need to adjust my Xenon to a flatter angle. They are pointing too far down and I can only see about 20 feet in front of me. So should I use the Vag method or the manual adjustment?
Edy
2000 Audi S4 STG 3
FATS = 3.66 w/ 91 oct
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 01-19-2006, 10:37 AM   #2
S4 SOM
Account #: 31255
Default <tracking>
S4 SOM is offline   Reply With Quote
Old 01-19-2006, 10:38 AM   #3
EdyJun
Account #: 48484
Default ya, me too ;p
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 01-19-2006, 10:40 AM   #4
WindyCityS4
Account #: 52314
WindyCityS4's Avatar
Default I tried both, prefer the manual method. For me, it is easier and faster.
In a world of constant change, it is the learners that shall inherit the future. For the learned soon find themselves capable of living in a world that no longer exists.
Autobahn Country Club (North, South, combined), Blackhawk Farms, Gingerman, Grattan, Mid-Ohio, Putnam Park, Road America, Sears Point, Thunderhill and "The Ring"
WindyCityS4 is offline   Reply With Quote
Old 01-19-2006, 10:42 AM   #5
mbox
Account #: 86816
Default iirc, you have to vag first then do the manual vertical adjustment.
I could sware you had to do both but this was a while ago. I remember it was something like install new lights, get on level ground, run vag, then adjust vertically.
mbox is offline   Reply With Quote
Old 01-19-2006, 10:42 AM   #6
BlackS4tt (Josh)
Account #: 68919
Default use the manual method, and then run an adaptation with the VAG so you dont lose your autoleveling.
Email: blacks4tt AT yahoo.com
VAST Tuned Stage III, Blouch 997 KO4s, Custom FMIC, Stoptech, OZ
BlackS4tt (Josh) is offline   Reply With Quote
Old 01-19-2006, 10:44 AM   #7
Hal_TT::CBP
Account #: 3027
Default Thinking the VAG just zero references the levelers(suspension switches) and the headlight motors.
Don't think there is any VAG functionality other than zeroing the sensor settings ie set the headlights with the car level(using the adjustment knobs on the housings and with the VAG plugged in in "learn" mode) and then tell the VAG you are done by progressing to the next block in VAG.
Headlight adjustments are done with the manual lens adjusters... just have to tell the car through VAG that these are the zero settings so it won't point the lights at the ground or sky if the car sensors are telling it to based on a bad zero measurement.
Hal.
Whoops...
I wanna ride...
APR Stg3 (and then some) Sold.
Hal_TT::CBP is offline   Reply With Quote
Old 01-19-2006, 10:47 AM   #8
ModifiedA4
Banned
Account #: 143
Default headlight aiming article..
to answer your question, you should really re-aim your headlights correctly, using the vag and manual levelers.
ModifiedA4 is offline   Reply With Quote
Old 01-19-2006, 10:52 AM   #9
Toasty-Stg3::HCBP
Account #: 35508
Default Change your blinker fluid first! The adjustment won't stay if you don't...
:P
Toasty-Stg3::HCBP is offline   Reply With Quote
Old 01-19-2006, 10:58 AM   #10
GrandPaJohn
Account #: 3954
Default That's the way I understand it as well.
'00 Black/Silver S4
6 speed
239,000 miles and counting
STG 3 Power finally
•<a href="http://WWW.BONDABILITY.COM" target="_blank">Surety Bond Agent</a>
GrandPaJohn is offline   Reply With Quote
42, a6, audi, headlight, leveler, xenon
