Old 01-16-2006, 08:10 AM   #1
Hal_TT::CBP
Default Thoughts on overboost situation - N75/WG circuit likely cause?
My Omori gauge is reading about 0.1B off actual(or is close enough unlike what I initally thought). So, I've been seeing boost spikes to 1.7B for about a month now. Blew a BPV last week and replaced it(audiable rattle/air noise) but the problem persists. Have spoken with a few on this and everything points to the N75/pressure side of the WG(s) as the boost will hold steady if at part throttle(boost < 1B) but once going WOT it has an initial swing to 1.5B(will go higher if I let it) and then settles to 1.3-1.4B depending on pedal position.
If you log req=actual they are almost identical, minus the initial spike. holding boost in 5/6gears has the boost fluctuate about 0.1B 2x per sec with throttle held constant... leaking somewhere on the N75 circuit I think. I have not pressure checked the pressure lines to the WG actuators but will do this this week, also going to try another N75 valve as I've played with mine *a lot* over the years. Car idles and runs fine, even under boost with the exception of the new boost characteristics. I am assuming since it idles well that the spider and associated PCV system are in tact. Also, have had the car on a lift last week and all things there still look new, no housing/DP leaks. There is a slight hiss at the passenger rear on/off/on every few secs but I cannot tell if this is the EVAP line purging or something else leaking. The EVAP does cycle every 30 or so secs(audiable clicks) as expected. Going to pressure check things soon... in stock mode now.
Any thoughts?
Hal.
My German car history...
'11 S4 Premium +, 6sp, Ti, Nappa, Carbon, SportDiff, B/O, Nav/Park *current Audi *
'01.5 S4 Shizzle #3 ... purchased 09/03/10, Nogaro/Blue Sport
'10 Dodge DS Gen4 Ram 1500(designed by Germans lol)
'03 TT 225QC ... sold 09/23/10, Ocean/Sea
'01.5 S4 APR Stg3 ... sold 09/10/08, Silver/Silver
'01.5 S4 Ordered, Silver/Silver, Lemoned 5mos after purchase
'00 996 Cab, Blk/Blk on Silver
'98.5 A4 QMS Avant, Santorin/Ecru with blue trim
'96 Jetta GLX VR6
'95 Jetta GLX VR6
'92 E36 Coupe - Lemoned 4mos after purchase
Hal_TT::CBP is online now   Reply With Quote
Old 01-16-2006, 08:19 AM   #2
dscottjr
Default Sounds like you're on the right track. n75s seem to be a bit sketchy after they've been tweaked.
00 S4, Euro spider hose mod!!
04 allroad, needs rs6 intercoolers, k04s and a cargo box...
dscottjr is offline   Reply With Quote
Old 01-16-2006, 08:29 AM   #3
davenew
Default does your car have the plastic wg hose tees?
When I first bought my car the plastic hose connector at the back of the engine was cracked. I think they're more of a Y shape than T. If you replaced something like diverter valves, doesn't it take xxx many miles for the ecu to adapt?
'00 S4 EPL Stg 3 (March'04-May'08)
'08 BMW 135i Dinan Stg 2 (May'08-Present)
'00 S4 Imola widebody, ASP GT28
davenew is offline   Reply With Quote
Old 01-16-2006, 08:53 AM   #4
Hal_TT::CBP
Default I think mine are plastic(Y's)... going to check these when I can let it sit a bit. Thx Dave.
Hal.
'96 Jetta GLX VR6
'95 Jetta GLX VR6
Old 01-16-2006, 08:55 AM   #5
Hal_TT::CBP
Default Yeah, wish audi had done a three wire with self-diagnosis...
Hal.
'96 Jetta GLX VR6
'95 Jetta GLX VR6
Old 01-16-2006, 10:11 AM   #6
EdyJun
Default Re: Thoughts on overboost situation - N75/WG circuit likely cause?
I would defiantly do the pressure test and check for leaks.
Have you though of EBC instead of replacing your N75?
Edy
2000 Audi S4 STG 3
FATS = 3.66 w/ 91 oct
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 01-16-2006, 10:52 AM   #7
davenew
Default ebc with apr? good luck:)
Old 01-16-2006, 10:57 AM   #8
EdyJun
Default Oops, didn't realize Hal_S4Shizzle::CBP had ARP.
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 01-16-2006, 11:27 AM   #9
davenew
Default hey, I left my ebc wired up (all but power).. so if anyone figures it out let me know:)
Old 01-16-2006, 11:58 AM   #10
EdyJun
Default If i find it i will post and add it to my site.
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</font>
00, 18t, 2000, 2002, apr, audi, b5, boost, issues, n75, overboost, overboosting, problem, s4, wot
