Old 01-04-2006, 05:36 AM   #1
STTPower
Account #: 92267
Default Just wanted to bounce some ideas around concerning the MTM chip.....
I did some searching yesterday, and found a few posts regarding how the mtm chip creates more low-end power by requesting(creating) boost spikes at low rpm. I was wondering if that was a bad thing. I'm trying to think mechanically if this was bad/good due to the obvious overspool issue with k03's. At that low of an rpm, would the k03 be spinning out of range, or would it be spinning within range but just more than average? Sorry if this sounds confusing, but I think you get my point. Anybody have any thoughts on this?
STTPower is offline   Reply With Quote
Old 01-04-2006, 05:52 AM   #2
S4Poor@Curbside
Account #: 98473
Default I am comfortable with the idea that MTM works WITH Audi to better it's products. That..
being said. I have a feeling that MTM & Audi try to keep all aspects of the programming to NOT put the K03's past their efficiency range. Just a guess, but it makes sense to me. Why would Audi want a company that they work with make a product that would ultimately make Audi pay for replacements for people still under warrantee? Just my $.02. Start the flaming...
S4Poor@Curbside is offline   Reply With Quote
Old 01-04-2006, 06:22 AM   #3
Captain Matt, I be
Account #: 26545
Default ask S4mig what he thinks of how MTM software treats K03s :)
Captain Matt, I be is offline   Reply With Quote
Old 01-04-2006, 06:35 AM   #4
S4Poor@Curbside
Account #: 98473
Default He loves it :-)
Old 01-04-2006, 07:45 AM   #5
'Nova more S4
Account #: 47523
Default if you want to run some logs, we can meet up to see if it does spike.
http://www.acna-nj.org
'Nova more S4 is offline   Reply With Quote
Old 01-04-2006, 08:13 AM   #6
STTPower
Account #: 92267
Default Nova S4 2k1....Are you running the MTM software?
Old 01-04-2006, 08:29 AM   #7
OSin456
Account #: 42092
Default Just makes boost sooner, it doesn't really "spike".
When i had the chip it would hit 1-bar at 2.2k as compared to maybe 1-bar at approx 3k for other chips. Held 1.1-1.2 and then tapered to 1-bar a little before, or @ 5k, and then held a bit above .9 until 6k and then slighlty below afer 6.5k.
The early boost build-up would not bother me mechanically (as long as it's not "spiking" more than it should, 1.2 bar). Holding boost at higher RPM's would.
ASP Stage 3 Avant
<a href="http://www.wunderground.com/US/CA/Hermosa_Beach.html?bannertypeclick=big2">
OSin456 is offline   Reply With Quote
Old 01-04-2006, 08:49 AM   #8
SchagenWagen
Account #: 44371
Default At engine low RPM, K03 should not be even close to spinning out of range
Now, in midrange, things could be close. How far the limits set?. You need to examine compressor map and calculate engine consumption for air based on RPMs and boost pressure you see.
In general, I don't see anything mechanicaly wrong with quicker spoolup
SchagenWagen is offline   Reply With Quote
Old 01-04-2006, 08:53 AM   #9
MNblackS4
Account #: 33171
Default I'm hoping to start some homebrew tweaks with my MTM stage 2 software
I put in K04s over Thanksgiving. I've been driving around with throttle cut for the last 5 or 6 weeks.
I'll be using an MBC, TCD, and '5 bar' FPR from Vast and tweaking with Lemmiwinks. Hopefully we get good results. I'll post something when we get started and make some progress.
EPL Stage 3
create your own visited states map
MNblackS4 is offline   Reply With Quote
Old 01-04-2006, 09:35 AM   #10
STTPower
Account #: 92267
Default Another quick thought of mine.....
I'm assuming 1.1 bar with mtm is only at WOT correct? So correct me if i'm wrong, but would half-throttle create around .5 bar? Has anyone ever tried this or calculated it before. If I can recall, the max boost for stock is around .6 or something. So driving half-throttle would never drive the turbo out of range. Am I right? Sorry if I'm just talking out of my ass, but i've been thinking about that for a while. Any feedback?
