Old 12-28-2005, 01:14 PM   #1
FixedWing
Default About to install a STaSIS LSD and need to know the part numbers for the drive shaft seals...
The differential is leaking gear oil so I want to replace all three drive shaft seals while it is out. Can anyone tell me the part numbers for these seals?
Thank you. :-)
LSD porn attached for your viewing pleasure.
Stephen
FixedWing is offline   Reply With Quote
Old 12-28-2005, 01:28 PM   #2
ryans4
Default #9 in this pic is: 016 409 399 B - 45x60x8, #6 is: N 905 144 01 - 171x3.5
ryans4 is offline   Reply With Quote
Old 12-28-2005, 01:33 PM   #3
FixedWing
Default Thanx Ryan. What about the front drive shaft seal? Guess it is #11 (x 2?).
Old 12-28-2005, 01:35 PM   #4
BUFFALONOGAROpebFATS
Default what about the gasket that goes into 12a?
took my driveshaft out this week to find a torn to bits gasket. must have been folded when the driveshaft was re-installed during a clutch replacement.
also, when i went to pull the shaft down it was kind stuck and i noticed i could hear air moving through something when i would shift the saft back and forth (this would be the pice going into 12a if i read that schem. right) normal or do i have a bad seal? thanks man
joe
CNPE founding member
BUFFALONOGAROpebFATS is offline   Reply With Quote
Old 12-28-2005, 01:46 PM   #5
ryans4
Default #11 is: 857 525 275 (yes 2 of them) and #16 is: 010 325 381 A - 90x4.2 ...
Old 12-28-2005, 02:15 PM   #6
FixedWing
Default I guess that is everything that could possibly leak. Thank you Ryan!
All cheap except the drive shaft seals which are $30/ea.! Figures.
Still, I'd rather replace everything while it is out so that I know I won't have any more leaking problems.
Stephen
Old 12-28-2005, 02:17 PM   #7
ryans4
Default i'm the same way, if you're in there, might as well replace the wear crap...
...always cheaper then having to go back just to swap out a $30 seal.
Old 12-28-2005, 03:24 PM   #8
NO.BRAZIL (barf)
Guest
Posts: n/a
Default What is number 30? Is that astro glide?
Old 12-28-2005, 03:33 PM   #9
Andrew C.
Default jb weld
- Andrew C.
now: 01.5 S4 Avant Pearl/Onyx Widebody
was: 98.5 A4 2.8 QMS Pearl/Ecru
Pearl White S4 Frappr
Andrew C. is offline   Reply With Quote
Old 12-28-2005, 09:40 PM   #10
Dr. Jekyll
Default oooo nice :-) gimme a call if you need a hand.
Dr. Jekyll is offline   Reply With Quote
857525275, a4, audi, b5, drive, forum, g052128a1, install, lsd, n90514401, seal, shaft, stasis
