Account #: 43051
I've STFA, seen sample photos and read write-ups for placing the unit behind the grille area. I'd like to attach it in a different location since (a) I'm worried that the jarring caused by opening an closing of the hood might affect the transponder's position if it is placed in behind the main grille and (b) my license plate sits very low on my RS4 bumper, so I'd like to get the transponder as close to the plate and main bumper cover facia as possible.
Here's a picture of where I'm thinking of installing the single transponder (I need to save up more $$$ before I can get a second transponder). I will likely pick the area highlighted in red on the driver's side as my first option. ![]() I noticed that there aren't too many places behind the lower grille area where I can attach the transponder's brackets, since the RS4 bumper mounting areas behind the lower grill section are different from the stock bumper. If any of you have the RS4 bumper and have done a similar type of install please offer advice. TIA.
Account #: 33628
mine is mounted to one of the flat bars on the stock grill.
Account #: 43051
movement after you slam the hood close? Have you had to adjust the transponder at all over time because of the jarring?
Account #: 67177
![]() 2001 2.7T / 6spd / Cold Weather Pkg. / Premium Pkg. EPL Custom Tuned Stage III / 93 Oct Bilstein-HD / B&G Sport Coils / H-Sports KO4/997 Hybrids, EV14 Inj, ASP MAF Vast Kevlar Clutch,RS4 PP & Throwout bearing Autospeed Trans. stabilizer bar AWE/McNeil Downpipes/graphite rapped AWE/McNeil Intercoolers APR exhaust/snub mount Port/Polished/Ceramic coat exh. mani's JHM short shifter Hardwired/stealth V1 |
Account #: 3779
way I have on my car (with moulding tape).
Account #: 48484
I am in CA and if a cop here suspects that I have one he has the right to search my car. So I am still trying to find a way to install it that the cop can not find it.
Edy
2000 Audi S4 STG 3 FATS = 3.66 w/ 91 oct AIM: EdyJun ![]() 11 September 2001 In their honor. In their memory. <font color="red">---------------------------------------------------------- <u><big> ![]() <a href="http://homepage.mac.com/edyjun1/S4/index.htm">EdyJun's S4 Directory (FAQ, DIY, Info, Tips and Help) </a> </big> </u>---------------------------------------------------------- </font> |
Account #: 40407
legal (under FDA jurisdiction).
I know some states (VA, and another one out West?and all of Canada IIRC) laser detectors also illegal.
00 S4 Silver/Black darintake (my way), RS4 airbox top, RS4 MAF housing allroad p/p intake mani (F hose delete!) with ASP phenolic intake spacers AWE IC's (IPP's up for sale) allroad TB, fuel rail, VAST tweaker chip, 37# delphis, MBC and TCD K04/RS6 'brids, p/p, clearanced hot side, z/c coldside with Induktion oil lines Piggie pipes, Twin 2 Achtuning OCK VAST kevlar clutch w/ re-surfaced and balanced flywheel APR bi-pipe, snub mount RS4 motor mounts, AWE DTS 19mm rear sway bar - awaiting install spare ECU with GIAC IBE2 w/ X, XR, etc. (shouldn't have started the mod thing) EPqC - Events and More... |
R.I.P.
Account #: 20137
I replaced the foam tape once, but that was it. Otherwise, it's been trouble-free and it's worked very well. You get an 18 inch radius, so you should be fine there.
#10 |
Account #: 43051
| bumper, indent |
