Old 11-29-2005, 02:14 AM   #1
surfnturf
Default ASP vs. AWE MAF Housing
ASP says their billet housing is 85mm, AWE doesn't state size. Does anybody know the size of the AWE one? They look almost identical in the pics, so I'd assume it's close.
surfnturf is offline   Reply With Quote
Old 11-29-2005, 03:30 AM   #2
[badmoon]
Default AWE uses a stepped MAF
I believe someone said it was 102mm at the sensor, but it has a 45 degree step so it starts at like 78mm and steps up, two totally different designs. It depends on what software you'll be running. If you're going homebrew stick with the ASP one.
[badmoon] is offline   Reply With Quote
Old 11-29-2005, 05:29 AM   #3
2000s4biturbo::Uli
Default ASP is tapered. its not 85mm all the way through. just an FYI.
MY BABIES a.k.a. CARS
you want the best for your car? tell him i sent you.
FATS database
NOT stock ;^P
nogaro 6mt my00, casa 6mt my01.5
2000s4biturbo::Uli is offline   Reply With Quote
Old 11-29-2005, 05:55 AM   #4
DAP@EPL
Audiworld Sponsor
Default Because the S4 airbox outlet isn't 85mm.
IIRC, the ASP MAF starts at ~78mm (which is the max possible using the stock airbox) and gently tapers out to 85mm.
-Dave Pramanik
DAP@EPL is offline   Reply With Quote
Old 11-29-2005, 06:29 AM   #5
2000s4biturbo::Uli
Default that sounds right,.,
FATS database
NOT stock ;^P
Old 11-29-2005, 06:53 AM   #6
mbox
Default I couldn't use the ASP without straightening the airflow before the sensor.
Like others have said, AWE's is stepped and ASP's is tapered to fit the stock box but you have to modify the box before it will work correctly.
I ran crazy rich when the ASP MAF was mated with an unmodified stock airbox fouling my plugs and clogging my Delphi's. I have since made a custom 99/60 so the airflow could be straighter before it reaches the sensor.
I know most stage 3 cars are using modified airboxes so this may be true with more MAF's than just the ASP. I'm just recalling from experience.
mbox is offline   Reply With Quote
Old 11-29-2005, 07:18 AM   #7
Todd/A.W.E.
Default Hallelujah! People are finally seeing the light! ;) Step in housing is not the devil!
As we've been preaching forever, the turbulence originates *before* the MAF, which is why a laminar screen or cone filter helps smooth out the MAF signal.
The step is our housing is not the problem as you yourself have seen by having issues with a "stepless" design.
Thanks for sharing this info with the forum.
Todd Sager
President
A.W.E. Tuning
Order line: 1-888-565-2257
Tech line: 215-658-1670
Todd/A.W.E. is offline   Reply With Quote
Old 11-29-2005, 07:46 AM   #8
[badmoon]
Default If you have an RS4 airbox Buehn can make a straight thru 85mm MAF housing :P yummy
Old 11-29-2005, 07:51 AM   #9
Marin S4
Default anyone that has an extra AWE maf housing laying around kindly e-mail me.
Marin S4 is offline   Reply With Quote
Old 11-29-2005, 08:13 AM   #10
2000s4biturbo::Uli
Default or you can mod your box ;)
i run an 88 buehn right now.
FATS database
NOT stock ;^P
78mm, 85mm, air, airbox, asp, awe, epl, housing, maf, making, pipe, rs4, s4, stock, straightener
