Old 11-24-2005, 06:28 AM   #1
WECoyote-SuperGenius
Account #: 10452
WECoyote-SuperGenius's Avatar
Default Ok, it's been a couple of days now since i had both EGT sensors replaced and............
I can't believe how much better the car is running.
What all is affected by the EGT sensors?
Long Island, New York
WECoyote-SuperGenius is offline   Reply With Quote
Old 11-24-2005, 06:38 AM   #2
DAP@EPL
Audiworld Sponsor
Account #: 6924
Default EGT sensors have a significant effect on the air/fuel mixture of the car.
DAP@EPL is offline   Reply With Quote
Old 11-24-2005, 06:55 AM   #3
Hal_TT::CBP
Account #: 3027
Default ... as with DAP, for starters, the entire fuel loop =-)
I had a bad one(that I probably screwed up in my Stg3 install) and it took a while to catch a code. Finally died, I replaced it and all is well.
Hal.
Whoops...
I wanna ride...
APR Stg3 (and then some) Sold.
Hal_TT::CBP is offline   Reply With Quote
Old 11-24-2005, 07:04 AM   #4
Account #: 10452
Default EGT 2 was bad, replaced both 1 & 2 for good measure, big seat of the pants difference
Old 11-24-2005, 07:15 AM   #5
Account #: 10452
Default significant is an understatement, car feels quicker and smoother..........
btw: superseded part number
Was: 078-919-529-D
Now: 078-919-529-F
Old 11-24-2005, 07:15 AM   #6
BlackS4tt (Josh)
Account #: 68919
Default a bad sensor may not necessarily throw a code?
Email: blacks4tt AT yahoo.com
VAST Tuned Stage III, Blouch 997 KO4s, Custom FMIC, Stoptech, OZ
BlackS4tt (Josh) is offline   Reply With Quote
Old 11-24-2005, 07:18 AM   #7
Account #: 10452
Default mine did
Old 11-24-2005, 07:21 AM   #8
V6UnderPressure
Account #: 28345
Default What symptoms were you having?
Current: 2006 A6 3.2Q
-Oyster Gray/Amaretto
-Eibach springs
-S8 Rims 245/35/19
-AMI
-Lip Spoiler
Previous: 2001.5 Brilliant Black S4
-SOLD! And Missed dearly!
V6UnderPressure is offline   Reply With Quote
Old 11-24-2005, 07:34 AM   #9
Hal_TT::CBP
Account #: 3027
Default They throw intermittent ones that get cleared every so often, hard to catch those
as they don't light the CEL. I knew one of them was screwing up but didn't want to replace them both. Mine finally went into limp mode and lit the CEL on a WOT pull(stuttered some on other pulls so I kinda suspected EGT). Got a fault to ground DTC/CEL on B1 so that was that.
Ended up replacing both anyway though... just wanted to make sure that was the problem and not an O2, MAF or water sensor.
Hal.
Whoops...
I wanna ride...
Old 11-24-2005, 07:50 AM   #10
Account #: 10452
Default Details inside............
stock program = limp mode, no c/e light
ahem <clears throat>, 93 oct. program = boost, but didn't feel as fast as it should, car felt like it was hitting the rev limiter between shifts when accelerating at wot, still no c/e light and poor gas mileage. I really suspected a bad MAF. VAG-COM confirmed EGT Sensor 2.
078, 2000, 529, 529f, 919, audi, b5, bad, code, d, egt, replaced, s4, sensor, simptoms, symptoms, throw
