Account #: 86788
Since I've installed Ecodes, my headlights are so out, it's not even funny. I've got no idea how to aim them properly. I swapped all parts one light at a time, and they looked good, just not aimed. Then I played with one of them, and rotated it just a little bit (as I read a post where a guy thought the bulb might be in upside down...?? and now one bulb appears VERY blue, compared to the other. I guess I'll turn it back? I dunno what the hell's going on. My brights light the trees above me as I drive by. Also, if anybody's got experience wiring the city lights, I'd appreciate it....I've searched, nothing as usual. Thanks, guys.
1977 IH Scout-Awesome! (except the rust) 1981 GMC Jimmy- eh.....50/50, beater/cool 1986 5.0 Mustang Convert. Bad ass..spun the tires! 1991 5.0 Mustang GT-auto, FTL 1993 5.0 Mustang LX trunk. Built 306 ci- Booyah! 2000 Dodge Dakota....eh 2001 VW Jetta GLX VR6- Loved that car 2004 VW R32....Great intentions, poorly executed. 2000 Audi S4 Imola Yellow, soon to be STGIII!!! ![]() create your own visited countries map |
Account #: 93008
![]() SOLD: *2001.5 Silver B5 S4 - APR 93 Sauce - Piggies - After-run Switch - V1 Hardwired - Snub Mount - H-Sport Front & Rear Swayz - 710n BPVs - Bi-Pipe - Homebrew SS - Clear Corners NEW RIDE: 1993 GMC Sonoma - Lots of Rust - Clothes Hanger for Brake Release Mod - Cracked Windshield Mod - AKA the "beanermobile" Edy Jun's S4 Directory Step 1 - 3/4 throttle mod Step 2 - One touch up rear windows Step 3 - NASA Wheel repair Step 4 - Elec. Cutouts - Mark P's Cutouts - Bertwork's Cutouts Step 5 - Comfort Turn Signal (Auto 3-5 Blinks) |
Account #: 98862
I've going through this same issue. I would go the dealer and have them adjusted. They have a special machine for this. Good luck!!
Account #: 65572
the bulbs need to sit perfectly in the housing ( i.e. not upside down) otherwise you get no projected light, just an illuminated housing.
iirc the wire from the bulb should aim towards the drivers side on both.
![]() ![]() MY BABIES a.k.a. CARS you want the best for your car? tell him i sent you. FATS database ![]() ![]() NOT stock ;^P nogaro 6mt my00, casa 6mt my01.5
Account #: 6383
vs going more so upwards. Just no time to adjust..adjusting sucks
Account #: 560
Account #: 560
or does the beam cutoff look funky and curved.
funky usually means the bulb is not aligned in the socket properly. you know there are adjustment knobs on the housings, right? the white plastic 6mm hex key jobs? one is easily visible (vertical adjustment) on the inner side of the housings. the other, i think you need to access through a pear shaped hole in the fender on the outer side of the housing (horizontal adjustment). don't turn these too far in either direction. you can strip the plastic threads. also, you did move the self-leveling motor? or have the shipping plugs still installed, right? just wanted to check. |
Account #: 65771
Account #: 9327
first park your car like 15~20ft away from a wall on flat surface, do one side at a time.
Do driver side first, adjust the center of the beam level horizontal(try 24" off the ground) as the ground pointing straight ahead, then do passenger side, on the left side of the beam line it up with driverside __/--- __/--- and then turn the passenger side aiming to the right a little bit like 5 degrees. you can start with that first after adjustment you will need to use a vag to recode the auto leveling. I believe it is in tech section. Hope that would help
WMS: 818-997-6500 ASP:856-772-9500 ![]() ![]() || ASP Custom Tuned Stage 3 || 710P || Piggie DP || ASP 89mm Truedual || ASP TSB || APR Boost Gauge || RS4 Grille || || AWE Intercooler || C M Stage 4, 6 puck & LWFW || ASP Motor Mount || RS4 Tranny Mount|| StaSIS Motorsport Ohlins || || 18" Work W-ITS 901 || 245/35/18 ContiSport3 || Ecode || Modded RS4 Bumper || StaSIS Motorsport Alcon 6pot 355 || WMS Stage III: 3.54 fats on Pump 3.25 fats on Race gas both runs were on pump file 3.06 on East Coast Pump Gas/Race File 2.93 on East Coast Pump Gas/Race File in 40f weather
