Old 11-07-2005, 10:31 AM   #11
Oo.et.oO
Account #: 65580
Default hmmm... that user ID thing never works for me. standing... corrected.. remaining... lazy
For Sale: B5 A4/S4 avant boot/trunk rubber mat
Gone but not forgotten: 2001 Brilliant Black S4 Avant 6spd.
c'mon AoA, where is the B8 3.0 TDi?
Oo.et.oO is offline   Reply With Quote
Old 11-07-2005, 10:32 AM   #12
PSmalls::DoggieStyle
Account #: 69223
Default Thanks to Verruckt, found Stasis' recommendations on their site....
All these years, I never realized they had a FAQ on recommended alignment specs for different setups.
Old 11-07-2005, 10:33 AM   #13
dscottjr
Account #: 42392
Default lmao. You are using the number and not the name, right? The name doesn't do jack any more which
SUCKS!
00 S4, Euro spider hose mod!!
04 allroad, needs rs6 intercoolers, k04s and a cargo box...
dscottjr is offline   Reply With Quote
Old 11-07-2005, 10:35 AM   #14
Oo.et.oO
Account #: 65580
Default indeed. i'm only partially a moron. second that it sucks.
Old 11-07-2005, 10:47 AM   #15
Imolavirus@BuehnEngineering
Account #: 33927
Default some suggestions here too...........
-Jacob
<big>Items For Sale</big>
Old 11-07-2005, 11:13 AM   #16
O.W. Kenobi
R.I.P.
Account #: 20137
Default For granny street and aggressive track, I have the STaSIS aggressive street settings.
It's my daily driver, so I have to compromise between a track alignment and a street alignment.
O.W. Kenobi is offline   Reply With Quote
Old 11-07-2005, 11:15 AM   #17
dscottjr
Account #: 42392
Default You Sure They Aren't Aggressive Settings?
Old 11-07-2005, 12:04 PM   #18
k04/rs6north
Account #: 47960
Default make sure they will do a subframe adjustment if required - getting cross camber adjusted properly ..
is critical imo - otherwise they are just making compensations so your thrust angle is correct - it is probably a safe assumption that a Porsche shop can / will do this but ask if they will do it on your S4
if you have adjustable coilovers, I would get it corner balanced first with you sitting in it (i just had this done and you will be surprised how much lower the rear is adjusted as well as the right side to get a balanced car)
1/32 total toe-in is as aggressive as I would go - I once did 1/8th total toe-out and while the car is perfect on flat smooth roads, it is too sensitive to everything - including front tire pressures that are not exactly the same, etc - just not fun at all for street driving.
Having tried Istook adjustable control arms and a toe-out setup, I can honestly say that a good suspension (I now have Ohlins with 700/800, Hsports sway bars front and rear and corner balanced (front left tire at 25 inches all other wheels adjusted appropriately) gives you 95% of the performance of a very aggressive track setup without all of the drawbacks (bad tire wear, twitchy steering wheel, horrible rattling)
I would also add that next time you replace your clutch consider the high bias torsen - it makes a noticable improvement in the handling department while at the track (I think this more than the LSD)
2001.5 Nogaro S4
2002 Black Allroad 6spd
RIP Matthew Ammon aka O.W. Kenobi
k04/rs6north is offline   Reply With Quote
Old 11-07-2005, 12:37 PM   #19
SForceK04
Account #: 99609
Default Use some toe 3/64ths is great on the street. 0 toe has way too many problems on the street
SForceK04 is offline   Reply With Quote
Old 11-07-2005, 12:47 PM   #20
ryans4
Account #: 4359
Default i disagree. Unless you do a lot of highway, zero toe has less problems (i.e. tire wear)...
ryans4 is offline   Reply With Quote
2000, alignment, s4, settings
