#11 |
i thought you got the ITG open element from piggie? didnt you?
WMS: 818-997-6500 ASP:856-772-9500 ![]() ![]() || ASP Custom Tuned Stage 3 || 710P || Piggie DP || ASP 89mm Truedual || ASP TSB || APR Boost Gauge || RS4 Grille || || AWE Intercooler || C M Stage 4, 6 puck & LWFW || ASP Motor Mount || RS4 Tranny Mount|| StaSIS Motorsport Ohlins || || 18" Work W-ITS 901 || 245/35/18 ContiSport3 || Ecode || Modded RS4 Bumper || StaSIS Motorsport Alcon 6pot 355 || WMS Stage III: 3.54 fats on Pump 3.25 fats on Race gas both runs were on pump file 3.06 on East Coast Pump Gas/Race File 2.93 on East Coast Pump Gas/Race File in 40f weather
#12 |
I got a really good deal on the evo so it was just a cost efficient decision. If everything goes well, I will probably get a 86/60 ITG from Coastfab and cut about 3 inches off the evo pipe.
#13 |
#14 |
You shouldn't be having so many issues.
Furthermore, of course switching from OEM airbox to Evo intake will decrease your readings when using a bigger MAF housing like ASP. The stock airbox is inflating your airflow readings because of how it is mating with the ASP MAF. My setup, in contrast, is straight through with a RS4 MAF housing and stock airbox properly modded to fit. IMHO, you should either modify your stock airbox or stick with the EVO intake. Your car seems to run like crap with stock aribox inflating airflow readings considering you pulled max primary fueling or close to it and still ran quite rich. Lower airflow readings will enable you to pull less primary while also having a leaner mixture. |
#15 |
#16 |
