Old 10-23-2005, 04:44 PM   #1
Milpitas2.7T
Default Folks that installed RNS or played with the Gauge cluster wiring
There are extra pins that one should use to get the CANbus working with the RNS, how does one get those pins out? Not much light, my eyes are aging and I am not grasping how the pin should slide out.
Just looking for a quick, "the small hole above the wire/connector, put something small in that hole press then pull the unused/wire ocnnector out.
Help, I've destroyed one, only have a few left to actually use as spares (if I can get them out without any more destruction
Milpitas2.7T is offline   Reply With Quote
Old 10-23-2005, 05:12 PM   #2
Hal_TT::CBP
Default Push the little lock pin(access through the small window(s) in the plug) and pull it out.
Hal.
My German car history...
'11 S4 Premium +, 6sp, Ti, Nappa, Carbon, SportDiff, B/O, Nav/Park *current Audi *
'01.5 S4 Shizzle #3 ... purchased 09/03/10, Nogaro/Blue Sport
'10 Dodge DS Gen4 Ram 1500(designed by Germans lol)
'03 TT 225QC ... sold 09/23/10, Ocean/Sea
'01.5 S4 APR Stg3 ... sold 09/10/08, Silver/Silver
'01.5 S4 Ordered, Silver/Silver, Lemoned 5mos after purchase
'00 996 Cab, Blk/Blk on Silver
'98.5 A4 QMS Avant, Santorin/Ecru with blue trim
'96 Jetta GLX VR6
'95 Jetta GLX VR6
'92 E36 Coupe - Lemoned 4mos after purchase
Hal_TT::CBP is offline   Reply With Quote
Old 10-23-2005, 05:17 PM   #3
Milpitas2.7T
Default Are you saying that, since that is what I said to tell me or are you telling me because I'm
a moron and can't get that to work?
Tory
Old 10-23-2005, 05:59 PM   #4
Hal_TT::CBP
Default Lol, get a small flathead screwdriver, press it in the little slot and pull the pin out of the top..
Don't remember it being difficult but ya never know what talent others have hehe. Call me if needed, I'll email the number and will be up a bit.
Hal.
'96 Jetta GLX VR6
'95 Jetta GLX VR6
Old 10-23-2005, 06:42 PM   #5
Milpitas2.7T
Default Different connector? these pull from the bottom, Gauge cluster pins?
Anyways, I said screw it after I finally added enough light to the issue and saw how the pins were to pull out. However putting a small pinted device directly in and trying to pull down on the blank connectors did not work. although I can now pull wires in and out at will... Now I need the part number for the small female connectors that go with the Gauge cluster wiring..
Old 10-23-2005, 06:53 PM   #6
Hal_TT::CBP
Default Hmm, this is with the plug cap off right? Should pop right out once the cover is off.
Ring me if ya want.
Hal.
'96 Jetta GLX VR6
'95 Jetta GLX VR6
Old 10-23-2005, 07:57 PM   #7
Milpitas2.7T
Default Yes but they don't they still have a release, just going to find the part numbers and order more
connectors if possible. Or pay someone for 2 of their spares, since I don't believe i can get mine out now, think I jacked them up inside the lil window
Tory
Old 10-24-2005, 05:52 PM   #8
pearlwhiteS
Default I need two as well...
If anyone finds the part number or could supply me with two, I would really appreciate it. TIA
pearlwhiteS is offline   Reply With Quote
