Account #: 19401
Been under the car a few times to undo the 17mm nut - thing does not budge. Instead of kicking or hammering it off at the risk of ripping that rubber boot, would it make sense to disassemble the plastic sway link and replace it with the metal version?
Should make it easier no? Anyone go this route instead of bitching that they broke the plastic version? Thanks. |
Audiworld Premium Sponsor
Account #: 13830
We've sold dozens of these metal links for precisely that reason.
www.purems.com 866-397-5487 | Temecula, CA | mike@purems.com | Specials on Twitter! |
Account #: 70550
with vice grips, without damaging the boot if you're careful. I'd try to get it apart without damaging them first, and if you have to replace them, do the metal ones as Mike recommended. But if you can save the stock ones, save the money, as there is no real performance advantage to the metal links.
Account #: 81647
I ended up unbolting the upper bolts, and talking the bar with links still connected to the Dremel.
I had to cut the nuts off, then dremel in a screw driver notch in the end to put them back on. Once I had them off,I used a vice grips to hold the end of the joint and used a wire wheel and new nut to clean up the threads before re-installing. It worked good enough to get the new sway bar connected. Then I went out and bought metal end links..... I still need to put them on though. See sig for pic of them. |
Account #: 70550
those metal links you have in your sig are a PITA. I would recommend returning them or selling them and getting the metal stock ones from Mike or ECS.
Account #: 74688
http://www.stopshopanddrive.com/item...05465CMY%2Ejpg
http://www.stopshopanddrive.com/item...05466CMY%2Ejpg Yea yea . . . . <insert ECS is overpriced statement here> Dave |
Account #: 81647
Account #: 70550
don't know how they'll work with the h-sport bars, but with the neuspeed bar, you can only run the bar on stiff with non-curved links. They also cost more, and don't provide any performance benefit.
Account #: 53141
------------------- Bahn S4's non-fried non-breaded wing recipe Diet and Exercise: Paleo + Crossfit
#10 |
Account #: 60276
SUPPORT STEM CELL RESEARCH! "There are (shop)whores that do provide a valuable service. However, you appear as a whore with no orifices, therefore all you accomplish is space occupation." --Kartman "Those who would give up ESSENTIAL Liberty to purchase a little temporary safety, deserve NEITHER liberty nor safety" Benjamin Franklin
| 2000, bar, link, plastic, rear, s4, sway |
