Old 10-19-2005, 11:41 AM   #1
üBER.QIK
Account #: 41342
Default Poll: MAF g/s peak for the stage II or II+ crowd. Mine is 232 @ 6k+RPM
I've been looking at g/s rates in various threads/discussions - which usually involve the Stage 3 crowd.
If you're a 2,2+ ... what's your peak g/s using VAG?
Recent upgrades: K04s, RS4 Clutch, RS4 Engine Mounts, GIAC 3- ECU, Hitachi MAF, Vast Snub
üBER.QIK Launch>
üBER.QIK is offline   Reply With Quote
Old 10-19-2005, 11:48 AM   #2
üBER.QIK
Account #: 41342
Default Re: I think my peak was 297g/s at stage 2+
Yikes... I figgered I was low (hence the poll). Any thoughts on what my probem might be? My FATS time knda sucks at 6.1 sec. I've checked the usual stuff ... no boost leaks, cleaned MAF, clean filter, no CELs etc. obtw... I'm at 3k ft. elevation.
üBER.QIK Launch>
Old 10-19-2005, 11:53 AM   #3
ST'S4
Account #: 70073
Default that's not right at all...you should be at least in the 270's minimum
Bored 2.8/9.1CR/ASP Fueling
JE Pistons/034 Rods/2.4 or RS4 Heads
Complete OEM RS4 Intake/Vast Meth Inject
KO4's Clearenced/Port Polished
X-1 Intake/ER IC's/55w Ecodes
ASP Exhaust Heads to Tips
Clutchmaster Stage IV with LWFW
STaSIS Ohlins 700/800 AWE DTS
Alcons 355 6 Piston BBK
Built and cared by WMS and KeKe
<a href="http://www.wunderground.com/US/TX/Austin.html?bannertypeclick=big2">
ST'S4 is offline   Reply With Quote
Old 10-19-2005, 11:54 AM   #4
[badmoon]
Account #: 43125
Default your ecodes probably...
I was running 4.3-4.4 FATS at stage 2+ which consisted of X, piggie pipes to my milltek single, RS4 ic's, phenolic spacers, and darintake mod to the airbox...but that was pretty much it.
[badmoon] is offline   Reply With Quote
Old 10-19-2005, 11:57 AM   #5
PSmalls::DoggieStyle
Account #: 69223
Default I've got a few graphs....
AudiS4Guy's car (block 003) with AMS software IIRC:
SLPRS4's car with APR Race software:
Piggie and I, both running X chip stage 2+ setups:
As you can see, most cars are in the 255-270 range when near/at sea level. Unless you are well above sea level, I think you're reading are quite a bit lower than they should be. You may have a bad MAF sensor, or other problem, causing the low readings.
Old 10-19-2005, 11:59 AM   #6
Account #: 69223
Default Some cars at/near sea level don't even get those high of readings, let alone at 3k' elevation.
Old 10-19-2005, 12:00 PM   #7
Account #: 69223
Default I may be wrong, but seems like everything you're talking about took place in COLD temps.
In more average temps, those low of FATS times and that high of airflow readings are unheard of for that level of modification.
Old 10-19-2005, 12:01 PM   #8
Captain Matt, I be
Account #: 26545
Default my II+ MAF readings from a while back - 70deg ambient
Captain Matt, I be is offline   Reply With Quote
Old 10-19-2005, 12:03 PM   #9
BiturboBoy_V2.0_S3--
Account #: 13456
Default thats low. i was in the 260's at stage 1.
BiturboBoy_V2.0_S3-- is offline   Reply With Quote
Old 10-19-2005, 12:03 PM   #10
[badmoon]
Account #: 43125
Default Done in 40 degrees
MikeyB09 runs 4.2 FATS at Stage 2 on 92...some cars are just fast...I don't know what to tell you.
