- don't have the car back yet but this is what I have from Mike at Tyrolsport so far:
1) AWE KO4 code does work with a TCD (from Piggy) 2) AWE KO4 code does work with an Apexi 3) He has setup the car so far with 2 different programs: - 17psi to redline - 23psi to redline 4) He has not set it up using the gear based approach (differently for each gear) - If anyone has any comments about this would appreciate it His comments - car drives very smoothly - the car is a monster with 23psi and 23psi holds to redline Also, after calling Piggy, he was able to get Piggy's intake phenolic spacers to hook up with the APR's bi-pipe (this was what others posted when I asked the question 1 week ago) I will try and get some FATs runs in the next 3 weeks.
2001.5 Nogaro S4 2002 Black Allroad 6spd RIP Matthew Ammon aka O.W. Kenobi
AWE software?
gear judge values=
1st: 157 2: 083 3: 54 4: 43 5: 34 set fb speed to 8 across the board set car select to 6cyl, and speed8. it should come programmed with speed at 4
![]() ![]() MY BABIES a.k.a. CARS you want the best for your car? tell him i sent you. FATS database ![]() ![]() NOT stock ;^P nogaro 6mt my00, casa 6mt my01.5
- He is going to test out the car with a wideband tonight / tomorrow
- I will have to spend a day, hoping Mike Moore will help, tweaking it for each set-up - I thought these two different psi set-ups were a decent start as it would give me a conservative (17psi) track setup and balls to the wall (23pi) set up thoughts?
I remember you were adding fuel and part throttle fuel trims were getting quite rich while WOT 02 voltages didn't budge much. IIRC, Mike Moore took a look and suggested getting new 02 sensors. Did that fix the problem? Maybe you need a new fuel pump?
'00 S4 EPL Stg 3 (March'04-May'08) '08 BMW 135i Dinan Stg 2 (May'08-Present) '00 S4 Imola widebody, ASP GT28 |
#10 |
