Old 10-10-2005, 04:59 PM   #1
k04/rs6north
Account #: 47960
Default APR Bipipe & Pippy Phenolic Spacers - install tips ??? ....
My mechanic was / is having problems
I hooked him up with Piggy late today so hopefully this will fix the problem - crossing fingers
But for others that may home install, might be worthy of a tech article / Ed directory, are there install tips to get bipipe and VAST Phenolic Spacers installed??
thanks
2001.5 Nogaro S4
2002 Black Allroad 6spd
RIP Matthew Ammon aka O.W. Kenobi
k04/rs6north is offline   Reply With Quote
Old 10-10-2005, 05:03 PM   #2
reefer_bob
Account #: 45294
Default The mounting brackets won't fit.....
Reefer_Bob.
AIM: reeferbob
R.I.P. Matthew Ammon aka O.W. Kenobi
reefer_bob is offline   Reply With Quote
Old 10-10-2005, 05:03 PM   #3
EdyJun
Account #: 48484
Default <Tracking>
2000 Audi S4 STG 3
FATS = 3.66 w/ 91 oct
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 10-10-2005, 05:06 PM   #4
k04/rs6north
Account #: 47960
Default can you expand on this - people say it is possible (including Piggy) my mechanic says no -thx
2001.5 Nogaro S4
Old 10-10-2005, 05:18 PM   #5
Jeff Vader - boscoj
Account #: 15888
Default Pippy pipes . . .
__________________________________________________ _______
*** RIP MATT AMMON. YOU WILL BE MISSED ***
Jeff Vader - boscoj is offline   Reply With Quote
Old 10-10-2005, 05:31 PM   #6
Hal_TT::CBP
Account #: 3027
Default Its maybe not an issue with an EFK. If you have a normal/stock fan(belt driven viscous)
you'll definitely have to tilt the pipipe towards the drivers side if you want it to clear.
(1) On the pass side loosen the 10mm metal slider bracket(bolt behind intake tube) and pull it all the way forward.
(2) Place the bipipe on the TB, tilt it to the drivers side some(I had to open up the bottom bipipe mounting screw hole with a drill so all three bolts would line up) and screw the drivers timing cover bolt in, make sure the timing cover dimple and the bipipe seat together.
(3) Insert/tighten the drivers side down a little.
(4) Slide the pass bracket over the timing cover bolt boss on the bipipe(this tang will not have a bolt in it), it will be held on by the bracket from now on.
(5) Insert and then tighten the 3 TB bolts - do not overtighten any of these.
(6) Push the pass bracket back on the bipipe tag until snug, tighten the 10mm bracket bolt.
(7) Install the rest of the bipipe hose hardware and tighten.
Bipipe should be nice and snug, and will clear the fan as stock does. I have not done this with Piggies spacers but works fine with the ASP ones, no leaks, no rubs. One thing to note is the passenger headlight may rub the bipipe/IC hose slightly. My RS4IC hose is now 3/4" off the bumper shock rail on the pass side, normal on the drivers. I adjusted the headlight front cup a bit and everything fits... even my AC hoses fit better with the RS4IC raised a bit. Works well.
Hal.
Whoops...
I wanna ride...
APR Stg3 (and then some) Sold.
Hal_TT::CBP is offline   Reply With Quote
Old 10-10-2005, 05:44 PM   #7
k04/rs6north
Account #: 47960
Default I'm not sure what gutted stock downpipes and my question have in common?
2001.5 Nogaro S4
Old 10-10-2005, 06:15 PM   #8
Hal_TT::CBP
Account #: 3027
Default spelling in parent thread...
Hal.
Whoops...
I wanna ride...
Old 10-10-2005, 11:02 PM   #9
Tomasz@Startup
Account #: 683
Default Ha, you may have just saved me $250.
Tomasz@Startup is offline   Reply With Quote
Old 10-11-2005, 02:40 AM   #10
Imolavirus@BuehnEngineering
Account #: 33927
Default On the BiPipe or the spacers?
I've got spacer kits if you're looking for one.
-Jacob
<big>Items For Sale</big>
