Old 10-10-2005, 10:54 AM   #1
EdyJun
Default (17964) Charge Pressure Contr. Negative vs. (1796) Charge Pressure Contr. Positive
Can some one explain with great detail, what are the differences between these two?
17964 P1556 Charge Pressure Contr. Negative Deviation
vs.
17965 P1557 Charge Pressure Contr. Positive Deviation
I.e. If the difference between spec and actual boost is great than xx Mbar Negative Deviation is detected.
Edy
2000 Audi S4 STG 3
FATS = 3.66 w/ 91 oct
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 10-10-2005, 11:09 AM   #2
vegasS4
Default Negative means the system is not getting the requested boost (usually boost leak). Positive means..
the system is getting more boost then requested (ie Ko4's on Ko3 software)
L10 AWE Stage III tip
vegasS4 is offline   Reply With Quote
Old 10-10-2005, 11:17 AM   #3
[badmoon]
Default I think the deviation is 300mbar...when actual is positive or negative of requested
[badmoon] is offline   Reply With Quote
Old 10-10-2005, 11:18 AM   #4
EdyJun
Default Positive means: the system is getting more boost then requested (ie Ko4's on Ko3 software)
SebGood is 100% stock except for GIAC X and he is getting P1557 - Charge Pressure Contr. Positive Deviation. He is not using K03 software on K04s how do you explain that? Boost leak, weather temp, or something else?
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 10-10-2005, 11:24 AM   #5
EdyJun
Default Thank you, this is more like it, some #s to back it up...
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 10-10-2005, 11:25 AM   #6
dscottjr
Default This # is software dependent.
00 S4, Euro spider hose mod!!
04 allroad, needs rs6 intercoolers, k04s and a cargo box...
dscottjr is offline   Reply With Quote
Old 10-10-2005, 11:25 AM   #7
[badmoon]
Default Keep in mind this can happen in off throttle situations...
Take a look at some ECUx logs and you'll see there's a slight actual boost spike off throttle...had something to do with bad BPVs I believe.
Old 10-10-2005, 11:26 AM   #8
[badmoon]
Default thanks for the info. I wasn't sure, I thought someone had mentioned that number :P
Old 10-10-2005, 11:27 AM   #9
EdyJun
Default I c, I take it after market chips have a higher threshold. (i.e.instead of 300 mbars, its 500 mbars)
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 10-10-2005, 11:28 AM   #10
ryans4
Default Bentley says +/- 20 mbar deviation (for stock ecu)
ryans4 is offline   Reply With Quote
17964, 17965, 18, 2000, a4, audi, charge, code, control, deviation, negative, p1556, p1557, positive, pressure, s4
