Old 09-30-2005, 12:55 PM   #11
zhenya
Default Thanks. Got it now I think. I'll try to re-graph.
zhenya is offline   Reply With Quote
Old 09-30-2005, 12:56 PM   #12
Imolavirus@BuehnEngineering
Default quit sucking up :p
-Jacob
<big>Items For Sale</big>
Old 09-30-2005, 12:58 PM   #13
zhenya
Default Thanks man! It's a lot nicer now with a clutch that holds!
Old 09-30-2005, 12:59 PM   #14
zhenya
Default So if I did want more...where should I start?
Old 09-30-2005, 01:02 PM   #15
PSmalls::DoggieStyle
Default Do you have Lemmiwinks? If so, open it up and click "read." Then take a print screen shot of it and
post it please. Thank you. I can't remember if your car ran like a champ out of the box or took a couple tweaks, just was curious.
Old 09-30-2005, 01:04 PM   #16
zhenya
Default Yes I do. Everything is set to default values.
Old 09-30-2005, 01:07 PM   #17
silvino
Default Why doesn't anyone spring for a wideband to see the useful AFR data?
Timing looks good compared to other logs I've seen around. I assume you're using some type of mixture of 100 octane .
silvino is offline   Reply With Quote
Old 09-30-2005, 01:09 PM   #18
nyet
Default DAMN, that is amazing. your fueling/MAF look dead on.
seriously. good job.
"It's easier to practice medicine without a license in this country than it is to get info on tuning Motronic." -JasonS9
ECUxPlot - my java based ECUx/VAGCOM/VCDS plotter
My hacked version of Flyboy's ECUx template.
S4Wiki - CONTRIBUTE TODAY!
Web based FATS calculator for ECUx and VAGCOM logfiles
Sync your iPod under Linux!
Definitive S4 DIY Thread of Doom
AWOT Brain Trust #101
AWOT Axis of Evil Member #6
Member, Aw0t Fish Taco Dinner Club
I say to you that the VCR is to the American film producer and the American public as the Boston strangler is to the woman home alone." - Jack Valenti, President and CEO of the MPAA
this site is NOT for information sharing
it's strictly for multiple monologues
that result in none of the participants
changing their point of view
- frank
nyet is offline   Reply With Quote
Old 09-30-2005, 01:10 PM   #19
nyet
Default i dont think you should touch anything, imo.
you could pull some fuel if you have access to decent pump gas.
what are your trims at (block 32)
- frank
Old 09-30-2005, 01:11 PM   #20
Default Turn the MBC clockwise and re-log 003/031. Read inside first, though....
What you want to watch is MAF (G/S) and primary 02 sensor voltages. You want to stay ~300 g/s at the most IMO and thus keeping your 02 voltages >.85 or so. How close you get to that depends on how close of an eye you want to keep on the car. Remember, temperature drops will create denser air which will in turn create higher MAF #s which will in turn cause the injectors to inject more fuel. Therefore, you come closer to maxxing out the stock MAF and injectors as temperature drops. That's why lemieux recommended turning boost down when it gets colder. The closer you are to the threshold of maxxing these out, the closer eye you need to keep on MAF/02s so you can adjust boost accordingly. If you're not comfortable doing this, just leave it be and enjoy.
Here are some examples of logs I took when I was stage 3 minus. You'll notice how when MAF gets high enough, 02 voltages drop (go leaner) because the injectors of maxxed out and the extra airflow is causing a higher air/fuel ratio:
Notice the shape of the MAF curve
Notice how the 02 voltage curve is the direct opposite.
If you convert this to duty cycle {ms*(RPM/1200)=DC%}, you'll see they are definitely maxxed.
