i'm not hitting full boost until about 4000 - 4200 RPMs. would an incorrect wastegate cause problems? i'm running N75 not MBC.
thanks myfootsmells
SoCal Mechanic/Installer - Jose "El Diablo" @ Euro-Tech B5 S4 FATs Calculator Web Based FATs Calculator/FATs DB/VAG Locator Tuning - Jeff Moss @ torque-factory.com Parts - Mike "Piggie" @ vastperformance.com |
![]() ![]() L10 AWE Stage III tip |
If you're using K03 software I'd *definitely* try that first.
N75 duty on K03 code can really make for some limp low-end boost with larger turbos. |
If it doesn't spool with a properly adjusted MBC then you should look toward adjusting the wastegates.
#10 |
| adjusting, boost, k03 |
