Account #: 47960
Just went out and did 3 logging runs
1) +1.5 timing +1.5 primary (2nd gear run) 2) 0 timing + 3 fuel (3rd gear run) 3) 0 timing + 5 fuel (3rd gear run) I filled up with 94 Octane today The AWE KO4 Code with the K16s runs lean for power without adding fuel Run 1 - seeing 10 - 12 degrees timing pulled, some 23 knocks and only .82 / .83 O2s at 6500 rpm Run 2 - seeing 7 - 11 degrees timing pulled, 16 to 18 knocks and .84 / .85 O2s at 6500 rpm run 3 - seeing 8 - 11 timing pulled, 14 - 19 knocks and .855 O2s at 6500rpm Run 2 FATS =4.62 Run 3 FATS = 4.39 On my long drive back to NY tomorrow, I will add primary to +7 then up again until I get .875+ 6500rpm O2s I am still very surprised by the low timing numbers - we shall see if increasing Primary fixes this
2001.5 Nogaro S4 2002 Black Allroad 6spd RIP Matthew Ammon aka O.W. Kenobi
Account #: 9725
________________________________________ 2001 S4 6-Speed Santorin Engine/Drivetrain: ASP Custom Tuned Stage III Fueling, RS4 Y-Pipe/Clutch/Fuel Pump/IC's, X1 Intake, Samco F-Hose, APR Bi-Pipe, Piggie Pipes, Miltek Single, AWE DTS, APR Snub, TG SS, VAST Water/Meth Kit. Suspension/Brakes: Vogtland GT, Neuspeed Rear Swaybar (Med), Stoptech 332 BBK. Exterior: 18" BBS CH, M3 Lip Spoiler, SPP Foglight Bulbs, RS4 Grill, E-Codes. Interior: UUC Alcantata Boot, TwinData EFU, Strat S4 Logo Floor Mats, HW V1, PhatBox. |
Account #: 72863
"No, a flux capacitor is not compatible with a ham sandwich." |
Account #: 69223
I don't think you can blame the turbos. If you flow more air, the MAF #s go up and more fuel is injected. Tweaking fuel is only to adjust the air/fuel *ratio*, but the ratio should be fine right out of the box.
Account #: 9725
Account #: 69223
Otherwise, why buy the setup in the first place if you need to tweak it to run correctly.
Account #: 9725
are even running with these kits.
Account #: 15175
Sport Compact Car 2007 Ultimate Street Car Challenge Winner Jeff Moss, ASE Certified (A1, A3, A4, A5, A6, A8) <a href="http://www.torque-factory.com">Los Angeles area GIAC dealer for Audi, Bentley, BMW, Mini, Porsche and VW. ![]() Torque-Factory, Inc.</a> Torque-Factory Support Forum |
