Old 09-05-2005, 08:22 PM   #1
Formerly 1bads4::WMS
Account #: 63140
Default Are there any injectors that will fit rs4 mani and rs4 fuel rail
that are as big as green tops. I need more fuel
S4 No More.
Formerly 1bads4::WMS is offline   Reply With Quote
Old 09-05-2005, 08:46 PM   #2
Mike2kS4
Account #: 38083
Default Erf, not really.
I think Dahlback can sell you a set for a price that would make you wish you were the soap-boy in sing-sing.
You can just drill out your manifold to accept the larger bodied injectors. That's what I'd do. You also can always use the adapters to go back to RS4 injectors if you want to.
Old 09-05-2005, 08:50 PM   #3
Funkweasel
Account #: 28517
Default There are some siemens injectors that should fit as well. I can't find the link
though. There are some Bosch EV14 injectors that work as well.
Funkweasel is offline   Reply With Quote
Old 09-05-2005, 08:52 PM   #4
Mike2kS4
Account #: 38083
Default Siemens, ewwwww...
Which EV14? I only saw cute little ones Maybe a skyline or something takes those?
Old 09-05-2005, 08:57 PM   #5
Funkweasel
Account #: 28517
Default What's wrong with the Siemens ones? I dunno the model # on the EV14 but I
recall a compact form factor being available in a nice big flow rating. I think you can even spec them with an angled pattern.
Otherwise Magnetti-Marelli makes a 490cc@3bar injector that fits.
Old 09-05-2005, 09:11 PM   #6
Mike2kS4
Account #: 38083
Default I tested some for another car a while back...
All of them had the straightest pattern I ever saw, like they were made for a tractor or some kids squirt gun. Maybe they got better :/
I'd try to hunt down a fan pattern bosch, that'd rock.
Old 09-05-2005, 09:16 PM   #7
Account #: 63140
Default I ran some logs and I am maxed out on fueling and I am still
running lean. If I cant change injectors what should i do for more fuel?
S4 No More.
Old 09-05-2005, 09:16 PM   #8
Funkweasel
Account #: 28517
Default Yeah they have a fairly narrow pattern, but I believe there is a wider
one available, a bit like the greentops 'fire hose' pattern.
Old 09-05-2005, 09:18 PM   #9
FrozenS4
Account #: 85329
Default What fuel pressure are you running with the RS4 injectors?
FrozenS4 is offline   Reply With Quote
Old 09-05-2005, 09:21 PM   #10
Account #: 63140
Default 4bar and I was thinking about going either adjustable ecs
FPR or motorsport 5bar
S4 No More.
