Old 09-05-2005, 01:06 PM   #1
1SeriousPig
Default got a code today, charge pressure negative deviation, what the hell is that?
_______________________________
1SeriousPig is offline   Reply With Quote
Old 09-05-2005, 01:10 PM   #2
O.W. Kenobi
Rest In Peace
Default Write the code down, plug it into STFA before asking us, and see if that solves your problem.
You'd be surprised what you might find in the archives. Chances are, someone has had the same code and posted about it before.
O.W. Kenobi is offline   Reply With Quote
Old 09-05-2005, 01:13 PM   #3
-SlowSilverTIPJason-
Default It means your actual boost is lower then the requested boost, either bad boost leak or N75 valve.
-SlowSilverTIPJason- is offline   Reply With Quote
Old 09-05-2005, 01:22 PM   #4
burningcoals
Default what are your mods are you running TCD?
X Sauce
RS4 Grill
RS4 Clutch
RS4 18" Reps
Custom SS
AWE Twin1
AWE A-Pillar BG
APRV1 Downpipes
Test Pipes
StaSIS Streets
Forge BPV
20% Tint
Phatnoise
MBC
Ready to be installed:
K04's and assorted hardware...
burningcoals is offline   Reply With Quote
Old 09-05-2005, 01:40 PM   #5
TwinTurboTerror
Default Damn, you are one feisty mofo. 8^)
TwinTurboTerror is offline   Reply With Quote
Old 09-05-2005, 01:42 PM   #6
PSmalls::DoggieStyle
Default Also can happen on XR with TCD or X+TCD+close to sea level (burningcoals).
Old 09-05-2005, 01:51 PM   #7
Default What's the workaround with TCD and XR? Pull some boost w/ lemmi or L308X?
Old 09-05-2005, 01:55 PM   #8
Default There's no reason to work around it. Those with XR and TCD, run MBC only...
Therefore, they get the code but it has absolutely no negative effect. If the N75 were in the loop, you'd go into limp mode.
If you try to pull some boost with Lemmi, you will get rid of the code by reducing the low RPM negative boost deviation.. However, from what I've seen you'll cut throttle in high RPM due to a positive devation once you lower boost enough to get rid of the low RPM negative boost deviation. Some of the fastest S4s on the planet are running XR + TCD and have negative deviation code, nothing to worry about as it has no negative effect whatsoever.
Old 09-05-2005, 02:06 PM   #9
Default gotcha, why not an XR for MBC guys to alleviate the DTC
Old 09-05-2005, 02:07 PM   #10
Default Huh? I don't understand. XR is what causes the DTC.
