Old 08-30-2005, 04:35 PM   #1
davenew
Default AVC-R wiring plan, so far
The AVC-R has six wires. Here's: color - function - wire connection on car. All wires tapped in at connectors near ecu.
1) white - vehicle speed - white/blue, pin 3 of black 10 pin connector behind ecu.
2) purple - RPM - green/blue, pin 2 of black 10 pin connector behind ecu.
3) gray - throttle position - brown/red, pin 3 of 15 pin white connector behind ecu.
4) red - power - red/green, pin 5 of brown 6 pin connector behind ecu. This wire supplies power to leak detection pump.
5) green - ground - I'll put it on a lug and secure with other ground wires on one of the grounding studs.
6) black - 2nd ground - same as green.
I plan on mounting the solenoid valve behind the firewall. I hate to run longer air hoses but the instructions also warn of installing it in hot environments.
'00 S4 EPL Stg 3 (March'04-May'08)
'08 BMW 135i Dinan Stg 2 (May'08-Present)
'00 S4 Imola widebody, ASP GT28
davenew is offline   Reply With Quote
Old 08-30-2005, 04:45 PM   #2
Funkweasel
Default What ecu are you?
Funkweasel is offline   Reply With Quote
Old 08-30-2005, 05:00 PM   #3
davenew
Default 2000, A box
I should check the wiring for 2001 & 2002 to be sure they're the same.
Old 08-30-2005, 05:03 PM   #4
Funkweasel
Default I'm pretty sure they aren't. I don't have the diagrams for the m & t boxes though. :-/
Old 08-30-2005, 05:06 PM   #5
RocketBoy
Default Are A and H the same? I would think H would be the same as M and T due to ESP and the Hitachi MAF.
RocketBoy is offline   Reply With Quote
Old 08-30-2005, 05:20 PM   #6
Funkweasel
Default I'd think h would be the same as m and t, but I'm not sure.
Old 08-30-2005, 05:35 PM   #7
Mike2kS4
Default Those *sound* right ;)
If you need me to run to the garage and take off my ECU cover to be sure let me know. I just followed the wiring diagrams in bentley.
The throttle position sensor never worked on mine, dunno why. It works fine without a signal anyhow.
Old 08-30-2005, 05:55 PM   #8
davenew
Default yes, I studied the bentley to verify those connections
I guess I should check and see what voltage range the japanese cars use for tps. I'd like to use it to help with possible part throttle issues with apr. Thanks for the offer, but as long as bentley is trustworthy, I'm OK.
Old 08-31-2005, 07:51 AM   #9
ryans4
Default do you have these?
2001 wiring diagrams from bentley
ryans4 is offline   Reply With Quote
Old 08-31-2005, 09:50 AM   #10
Funkweasel
Default Sweet Ryan, thanks!
discussions, plan, wiring
