Old 08-29-2005, 11:31 PM   #1
PSmalls::DoggieStyle
Default My car may not be anywhere near the fastest, but it sure as hell is consistent....
I can pull 3.9-4.0 FATS and 5.3-5.5 FATS+ times in 70+F at will in my car.
Tonight, I pulled a 3.97 FATS and 5.48 FATS+ in 73F with boost spiking to ~22 psi and tapering to ~20 psi.
MAF and Timing (highest RPM MAF peak I've seen on straight K04s, less timing pull back up top as well):
Correction Factors (look at cyl6, wtf?):
02 voltages (think I should lean it out a bit more?):
I'm open to suggestions for further tweakage although I don't want to go too aggressive. I'm considering pulling back a bit more fuel and seeing how that affects things. Any other brilliant ideas?
Old 08-29-2005, 11:33 PM   #2
Alex (lil' is 300)
Default I award you the king of graphs.
Alex (lil' is 300) is offline   Reply With Quote
Old 08-29-2005, 11:35 PM   #3
Default No way! We have Mark P, Wolfie, etc who are the true kings of graphing.
Old 08-29-2005, 11:47 PM   #4
EdyJun
Default you may want to look into cyl 6. high CF.
2000 Audi S4 STG 3
FATS = 3.66 w/ 91 oct
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 08-29-2005, 11:53 PM   #5
Default Thanks, Captain Obvious. ;-)
I think new plugs are in order anyways.
Old 08-30-2005, 12:28 AM   #6
Imolavirus@BuehnEngineering
Default i think that you should try pulling some fuel and see if you see any gains
with you being on 94 octane all the time you should be able to run slightly lower 02's, it's mainly the guys who have the crappy 91 who need to stick in the .87/.88 range. I've seen better results on .86ish volt's now that I found 94 to run on all the time
-Jacob
<big>Items For Sale</big>
Old 08-30-2005, 03:01 AM   #7
RS_F-Whore
Default Which blocks log the individual cyl timing retard? TIA
RS_F-Whore is offline   Reply With Quote
Old 08-30-2005, 03:26 AM   #8
Pop3
Default IIRC 020 and 021
Next mods: chipset with overboost option
and stg3 rims (folk+nittos) and interior ledlights
Pop3 is offline   Reply With Quote
Old 08-30-2005, 06:03 AM   #9
BUFFALONOGAROpebFATS
Default i thought we discussed that this car seems to run faster/better on the rich side?
as for cyl 6 maybe an injector isnt seated right? possibly the lil rubber insulator from the coil pack to the plug. fouled plug? maybe the entire piston is missing? would someone steal your piston? i would def check that out.
it is nice to run consistent sub 4's. i think your setup has the most time taken to ensure this. all the little stuff you and mike have worked out all seem to work towards this. congrats on that.
CNPE founding member
BUFFALONOGAROpebFATS is offline   Reply With Quote
Old 08-30-2005, 07:01 AM   #10
Christian (Stage Ow)
Default i think "would someone steal your piston?" is the funniest thing i've read on AW in awhile.
__________
"It's easier to practice medicine without a license in this country than it is to get info on tuning Motronic." -JasonS9
Christian (Stage Ow) is offline   Reply With Quote
