Old 08-26-2005, 04:38 PM   #1
Quattro-X
Account #: 57124
Default Need some help with DTC: Secondary Air Injection System, Bank 1: air flow too low #17831
Yes I STFA, but there is nothing conclusive on this one. Is the air injection speaking about the turbos? Or some pollution controll crap? Thanks in advance.
1998.5 1.8TQM
2000 S4
Quattro-X is offline   Reply With Quote
Old 08-26-2005, 05:04 PM   #2
DaveD4
Account #: 3015
Default This might be some help
I had a code like this on my A4 2.8 and it referred to part of the smog equipment. The problem was caused by rotting vac hoses leading to the air injection valves. On the 2.8, they are located on the back of the engine, one each side, near the fire wall. Don't know for sure if the 2.7t is the same, but you might want to look around back there for some vac lines.
hope that helps,
Dave
01.5 S4
stg 3
DaveD4 is offline   Reply With Quote
Old 08-26-2005, 05:08 PM   #3
Quattro-X
Account #: 57124
Default Good starting point. Thanks.
1998.5 1.8TQM
2000 S4
Old 08-26-2005, 06:00 PM   #4
Eric 2.7
Account #: 61325
Default Yep, that's emissions control stuff. The blower is right under the foam covered part
of your brake booster line and it branches out to a silver hatted valve at the back of each cylinder bank.
The silver hatted valves are vacuum operated so if you have a code for only one side, it is likely the vacuum line to that valve or the valve itself.
BTW, extra air is injected since the engine starts up rich to get the cats off to a quick start. It's only on tips, though, but I'm not sure why.
Eric
2000 A6 2.7T
DIY Mule:
Full Timing Belt Replacement, Cam Seals & Cam Tensioner Gaskets, Engine Mounts (TWICE! Thanks Hamburg-Technic/ECS), O2 Sensors, 2ndary Coolant Pump, '03 OEM Sport Suspension, H-Sport Sway Bars, Control Arms, Tie Rod Ends, CV Joint Boots & All Kinds of Maintenance Stuff.
Retired:
1996 A4 2.8 2wd 12v
1987 4000CS Quattro
1980 4000 2door (not even an "S")
Eric 2.7 is offline   Reply With Quote
Old 08-26-2005, 06:37 PM   #5
Quattro-X
Account #: 57124
Default Interesting you say that. My car starts a little rough sometimes.
Then it suddenly idles fine after about 15 seconds. This is good info. I'll pop the hood in the AM. Are these expensive parts?
1998.5 1.8TQM
2000 S4
Old 08-27-2005, 06:49 AM   #6
Quattro-X-2
Rest In Peace
Account #: 22927
Default I found a cracked hose. Good call.
Quattro-X-2 is offline   Reply With Quote
Old 08-27-2005, 06:09 PM   #7
Eric 2.7
Account #: 61325
Default Good news! Cheapest possible outcome.
Eric
2000 A6 2.7T
DIY Mule:
Retired:
1996 A4 2.8 2wd 12v
1987 4000CS Quattro
28, 2ndary, a4, a6, air, audi, b5, bank, injection, injector, pump, replacement, s4, secondary, system
