Old 08-26-2005, 11:34 AM   #1
Christian (Stage Ow)
Account #: 67845
Default System too rich DTCs. suggestions?
codes below. I was thinking I could pull some fuel back with lemmi. thoughts?
DTCs: 7/31/05 12:59 pm - 4 Faults:
MS STAGE 6.0 0003
P/N: 8D0 907 551 HA
Coding: 06711, WSC: 05052
16815 P0431 035
Warm up Catalyst Bank 2: Efficiency Below Theshold
16805 P0421 163
Warm up Catalyst Bank 1: Efficiency Below Theshold [Sporadic]
17537 P1129 163
Bank 2 Mixture Adaptation (Mult): system too rich [Sporadic]
17535 P1127 163
Bank 1 Mixture Adaptation (Mult): system too rich [Sporadic]
__________
"It's easier to practice medicine without a license in this country than it is to get info on tuning Motronic." -JasonS9
Christian (Stage Ow) is offline   Reply With Quote
Old 08-26-2005, 11:36 AM   #2
reefer_bob
Account #: 45294
Default Take out your BOV's?
Reefer_Bob.
AIM: reeferbob
R.I.P. Matthew Ammon aka O.W. Kenobi
reefer_bob is offline   Reply With Quote
Old 08-26-2005, 11:39 AM   #3
DAP@EPL
Audiworld Sponsor
Account #: 6924
Default Bad MAF?
DAP@EPL is online now   Reply With Quote
Old 08-26-2005, 11:39 AM   #4
Account #: 67845
Default :) no BOVs here. I couldn't handle the shame.
__________
Old 08-26-2005, 11:41 AM   #5
Account #: 67845
Default hm. used to get MAF codes, but switched to a new one awhile back and they went away.
suppose that's still an option, though.
__________
Old 08-26-2005, 11:44 AM   #6
DAP@EPL
Audiworld Sponsor
Account #: 6924
Default Could be bad O2 sensors
Old 08-26-2005, 11:44 AM   #7
reefer_bob
Account #: 45294
Default LOL! :)
Reefer_Bob.
AIM: reeferbob
Old 08-26-2005, 11:51 AM   #8
Account #: 67845
Default again, possible. 02s and MAF are about the same age.
I suppose either or both could be gone. I'll do some logging on Block 211 to see what comes up for the MAF. Thanks DAP.
__________
Old 08-26-2005, 11:54 AM   #9
jprice@CPS
Account #: 8422
Default Don't pull fuel back wihtout exhausting all other potential issues.
Also, there's a few reasons you could run rich.. (besides the BOV :-p )
In addition to bad MAF or o2 sensors (logs should show that), you may also have a boost leak. Before adjusting fueling, try and find out what else could be the issue. (if you pull fuel back now, then later fix a boost leak, you'll run super lean, not good)
Minnesota Audi Club
2001.5 Audi A4 1.8TQMS
APR Stage 3+, APR Exhaust, Eibach Pro Street Coilovers, Neuspeed 19mm rear sway.
jprice@CPS is offline   Reply With Quote
Old 08-26-2005, 12:02 PM   #10
PSmalls::DoggieStyle
Account #: 69223
Default I've never found 211 to be very helpful. Just log 003 and 031 seperately...
then post the info and list your mods. Based on that, we should be able to help you identify an 02/MAF issue.
17535, 18t, 2002, a4, a6, adaption, audi, b5, bank, code, codes, dtc, fix, mixture, p0431, quattro
